You can upload images when you post.
1. Go to
http://imageshack.us" onclick="window.open(this.href);return false;
Click on browse
2. Go to the picture on your PC that you want to upload.
3. Click on start upload.
4. After uploading is now in progress.
5. The window will not display anything untill the picture has finished uploading. This can take quite some time depending on the size of the photo.
6. Once your photo has finished uploading, you will see a little yellow frog, some lines of code and a thumbnail of your picture.
7. Copy and paste the second line of code(Forums) from the top into the posting(original window) where you want it to display. (You do not need to use the IMG buttons at all this way)
8. When you have finished writing the rest of your posting hit submit and there will be a clickable thumbnail of your pic in the posting.
You can also register an account and keep all your previous uploads together.
Alternatively use Photobucket. Write-up by Dutch Diver
Quote:
1) sign onto
http://www.photobucket.com2) Select Join now....and follow instructions
3) When username & password done, from home page enter into top right corner and login
4) Middle of screen, click on "Choose files" button
5) Select pictures from your hard disk
6) Wait for them to upload and your screen to auto refresh
7) Hover the mouse pointer over the picture and move cursor down to IMG code
when the line is highlighted press Ctrl C
9) Switch to this site and your post
10) Press Ctrl V
Enjoy!
