And also the cab/front floor if you make them... For about a 1960..Tiger0107 wrote:Hi there.
I am interested in Load bed floor for a double cab split window and also cargo floor for a split window.
Any idea or a rough estimate as what they would cost?
Replacing kombi loading and cargo floors
Tiger0107
- What model do you have?: 72 Early Bay Deluxe
Re: Replacing kombi loading and cargo floors
Kuven Aramugam
E-Mail:
Contact #: 083 716 4455
Current Ride:2003 Golf 4 GTI
FRC - 76mm ATP DP and 63mm Wildcat Zorst - Forge TIP - Forge DV.
Project - '72 Early Bay Deluxe
E-Mail:
- VW-rules
- What model do you have?: 1961 Bus
- Has thanked: 10 times
- dsan
- Twin Port
i hope not, the thought of importing in a load bed from gerson isn't appealing right now
Daniel
herbie123
- What model do you have?: a few
- Been thanked: 4 times
HI all VW Bus addict
Appoligies for the delay ,
I have worked out the price on replacing the full loading area of a Single Cab Kombi. (Split and Bay)
R1600.00 , this will be for , four sheets covering the whole area , 1.6mm Thickness
All other sizes (applications) I will work out and let everyone know
If you are interested please let me know so i can go "ahead and bend"
I will require 50% deposit on all orders , thank you
Based in Midrand/Centurion
Andreas
072 2295362
Andreas
072 2295362
- dsan
- Twin Port
nice one
next question, what about the treasure chest areas?
Daniel
- louisvr45
How much for the fleetline sc wide bed?(removable bed)?herbie123 wrote:HI all VW Bus addict
Andreas
072 2295362
Any idea of the price for labour only.eg if we supply the steel sheet?
Tiger0107
Hi Andreas,herbie123 wrote:HI all VW Bus addict
Andreas
072 2295362
Ok this sounds like great news..
I need loading area of a double cab split window and also the cargo floor (or treasure chest floor) for double can split window.
Kuven Aramugam
E-Mail:
E-Mail:
- lowlight
- Been thanked: 14 times
Would like DC loading area std thickness.
Are you planning to be at aircooled day on 3rd Oct ?
herbie123
Ok, here are the prices
Split bus ,single cab loading area , 2700 x 1640 , R1800
Split bus ,double cab loading area ,R1600
Splt bus ,inner passenger/luggage area ,1200 x 1200 , R950
Split bus ,single cab "treasure chest" , R950
Split bus ,double cab passenger area ,R950
Fleetline ,wide bed loading area also available on special request , (unique profile)
Bay window buses and all other bakkie loading areas also available on request ,
I do require a 50% deposit on all order please , thank you
Delivery would either be in Midrand or Centurion
Andreas
072 2295 362
011 9281240
Andreas
072 2295 362
011 9281240
Nice work! Now there are no excuses to let Split Buses rot away
- Junior
- Pushrod
- What model do you have?: Had a 75 + 64 beetle
SO when you starting to make beetle panels?
Tiger0107
Ok my order has been placed..
1 X Split bus ,double cab loading area
1 X Split bus ,double cab passenger area
Thanx Andreas....
Thanx Andreas....
Kuven Aramugam
E-Mail:
E-Mail:
- louisvr45
Hi andreas,herbie123 wrote:Ok, here are the prices
Andreas
072 2295 362
011 9281240
the measurements for the wide bed ( in total) 2770 x 1880 its 2 panels 2770 x 887 and 2270 x 1023
it overlap in the small sections
the profile: 8mm high; it start(horizontal) : 55mm, 8mm down,115,8 up(45 degree),30mm,8mm up,115mm, ....
I can make a drawing of the sheeting if you need one. Give me a price on bending the load area
Regards
Louis
herbie123
hi Louis
I do start my sheets with a 50 flat area before bending , to accomodate for the "side pannels"
all price are all mentioned above
SC split loading area , STD , R1800 , (not wide bed fleetline) i mention this as i think you busy with a fleetline SC
I have tryed my best to do it as close as possible to factory specifications
I am just offering a service to assit other guys n gals to get there busses back on the road
please call me if you need any other informatoin , numbers also provided above
