TOO MUCH END FLOAT
- BEETLEBEDONNERD
- What model do you have?: 74 beetle
TOO MUCH END FLOAT
Hi guys,
I need some advice please. When I depress my clutch my whole crank moves forward about 10 mm. How will I sort this out as I don't think this is normal? I was told this is a 1600 engine from a kombi that was fitted in my beetle. The oke told me I must have it linebored to get it sorted.Will this sort out the problem. Maybe thrust washers the problem? please advise!
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 321 times
Re: TOO MUCH END FLOAT
End float is the curse of type 1 engines. In theory you can adjust end float by using appropriate thicknesses of the three shims between the flywheel and crank but, in practice, this seldom works. Most end float, especially if it is more than a quarter of a millimetre, means the case has been hammered out and the engine needs to be rebuilt. Line boring is the usual way of making a case reusable, but I think most cases in circulation have been line bored too many times and they should be scrapped. I personally won't trust any line bore more than .25mm. In my experience, rebuilt engines where the cases have been line bored beyond .5mm won't last more than 25,000km before catastrophic failure.
However, IMPI assures me that the issue is not the size of the line bore (some engine builders will bore a case up to 3mm!), but whether it is straight. Most line borers are drill mounted and not capable of boring true. They will also not bore true if the line borer is even slightly dull.
Volkspares sells brand new type 1 engine cases for about R5k if you want to build a truly reliable or high-performance engine.
- fig
- Bus Driver
BTW, if you really have 10mm of end float, then the main thrust bearing has turned in the case and the case is likely scrap.
- IMPI
- Been thanked: 78 times
Some things I have found in engines Those which were rebuilt by my friend who used to be a mechanic back when we were still appies (btw the friend now works as a car watch) I have found no shims only one and the metal gasket plus the paper gasket and then all of this fastened with a chisel
once all of these happen it usually spells the end for the beetle engine
I have yet to strip one of the notorious silver or blue painted rebuilds to find the thrust not severely worn or a new oil pump. they seemed to rebuild fairly nicely and then re used the oil pump as I dont believe that they would use genuine vw oil pumps and every thing else aftermarket LOL the thrust was mostly due to the fact that it was incorrectly set to start with
- RICKY-R69
- Clutch
- Has thanked: 13 times
Can't the casing be alu-welded and machined back to specs
- fig
- Bus Driver
Type 1 cases are 97% magnesium and cannot be welded. Type 4 cases are aluminium and can be welded and remachined.
- RICKY-R69
- Clutch
Stupid question...
How do you know what type casing it is? I am new to this and they all look the same to me.
- fig
- Bus Driver
Type 1 engines are all those engines originally fitted to Beetles, ie 1200, 1300, 1500, 1600.
Type 4 engines were fitted to Type 4s (411, 412) and buses from 1972 (8/71), ie, 1700, 1800, 2000.
- Has thanked: 191 times
not true - they can be welded... expensive, but possiblefig wrote:Type 1 cases are 97% magnesium and cannot be welded. Type 4 cases are aluminium and can be welded and remachined.
- Has thanked: 4 times
- Been thanked: 98 times
YES, Mag, can be welded, I've had it done to save several casings.Tony Z wrote:not true - they can be welded... expensive, but possiblefig wrote:Type 1 cases are 97% magnesium and cannot be welded. Type 4 cases are aluminium and can be welded and remachined.
- IMPI
magnesium is a very reactive material and will corode to nothingif enough oxygen is supplied..... hence figs case burn. but luckily its form of corrosion is tough and forms a impervious layer of magnesium oxide. this layer protects the parent metal. the other caracteristic of magnesium is the fact that oil penetrates into the alloy and causes endless troubles when welding. almost all casings that i have seen welded looked like an aero (chocolate) with all sorts of bubbles in the weld
the way to tell magnesium from aluminium is to scratch the metal with a scriber magnesium will complain loudly whereas aluminium will hardly make a sound. BTW there were magnesium type four cases made in 69 but very few.
Yup I have one of these.IMPI wrote:BTW there were magnesium type four cases made in 69 but very few.
