Alternator external regulator
dkjinsa
What model do you have?: 1974 Beetle
Post by dkjinsa »
Hi Guys.
Since Monday, my ignition light glows when I remove the key and the battery is not charging.
I have replaced the regulator with a new one but the problem persists.
Where do I look now?
Cheers
David
JonnoDub
Oil Seal
Been thanked: 9 times
Re: Alternator external regulator
Post by JonnoDub »
dkjinsa wrote:Hi Guys.
Cheers
David
Is it wired properly, maybe its best to seek an auto electrician
Sent from my FIG-LX1 using Tapatalk
dkjinsa
Post by dkjinsa »
It is wired exactly the way it has been for the last 10 years.
Been thanked: 487 times
I think you have an earth fault somewhere that you need to find
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
If the light comes on when you switch the car off, you may have blown diodes inside your alternator
dkjinsa
Post by dkjinsa »
Thanks guys.
I had an internal regulator alternator on the shelf which I thought was FUBAR.
Gave it a good internal dusting, fitted it to my engine and it works fine.
I'll take the old one to an auto electrician and let them sort it out. It is nice to have a spare.
