calooker wrote:One quick check you can do (maybe a bit late) is pull and push on the pulley with some force, if it has any inward or outward movement then the motor has worn bearings or not rebuilt properly (wrong shims) 99% of the times the mileage is high and wearing out the bearings , you should not feel any movement not even just a little bit, that should tell you something.
will do this afternoon. Thanks calooker
