Power Inverter - 1000 watt
VIV
What model do you have?: 1962 beetle
Post by VIV »
Hi
Also have this unit....regular power inverter ( 1000 watt ), ideal for camping / outdoor use. Complete with battery clamp terminals and adapter. Brand new unit,sealed and bubble wrapped.
R450.00
Regards
Viv
Re: Power Inverter - 1000 watt
I would be interested in that. How much to post to Pta?
VIV
Post by VIV »
Pta bout R40.00......
VIV
Post by VIV »
Estimated Watts
When selecting a power inverter, please make sure it has enough power for your appliance. Just add together the watts for each item you may want to run at the same time. Keep in mind to also add about 15% to the total wattage to ensure you will have enough power to meet your needs.
The estimated watts for the appliances below are estimates; please check your manual or the appliance itself for the actual wattage required. Doing this will ensure you select the correct inverter the first time.
Please use this easy formula to determine the correct size DC to AC power inverter if you only have Amps:
AMPS x 120 = Watts
Example: 15 Amp Cooling Unit X 120 = 1800 Watts
Appliance Est. Watts
Cell Phone 24w CD Player 40w
iPod 120w Toaster 1200w
TV 25 Inch 175w Jig Saw 350w
Laptop Computer 65-90w Circular Saw 1250w
Computer & Monitor 400w 1/2" Drill 700w
Printer 75w Refrigerator 500w
VCR 50w Vacuum 750w
CPAP 200w Sump Pump 1000w
Blender 400w 40" Fan 1100w
Space Heater 1000w Iron 1000w
Coffee Maker 800w Satellite Dish 75w
Microwave 1250w PS2, Xbox 125w
Korn005
What model do you have?: '75 Fleetline
Post by Korn005 »
Can I correct?
Power (Watts) = Volts * Current(amps)
In South Africa the standard voltage is 230V thus it should be:
Watts = 230 x Amps
A question on your inverters, is it square wave or pure sine wave inverters? As one can not operate motors efficiently on square wave inverters as far as I know.
'75 Fleetline Splitty
'56 Unimog 411
'79 Unimog 416 Camper
'89 Hilux
vader
Post by vader »
Id love it but am looking for a 1KW converter..... :TIC:
forcecooled
Post by forcecooled »
Spot on Korn -
Motors, including diaphram type compressors that fridge's have will not start on a non sine wave inverter.
