Advice needed on USA mild performance imports
Been thanked: 539 times
Re: Advice needed on USA mild performance imports
Tony Z wrote:now that looks like a winner.
Dont forget to remove the fuel pump as I doubt this dizzy will fit with the fuel pump in place.
Works with your vacuum, and is also electronic advanced, with smooth graft, and eliminates dead spots,
its Brilliant.
OD_1
Oil Seal
What model do you have?: 1976 1600S
Post by OD_1 »
Thanks for the info guys,
that dizzy looks sweet Retrovan, the one part solution, and i love the fact that you're running it with 34 ICTs :flash:
But the thing i like the most about it is the price :hangloose: So i'm definitely gonna go for this one instead. With the other set my budget was getting murdered.
Sorry for my newbness, but if i remove the fuel pump then where do i put it??? I know ---- > :jerkoff:
I think i heard somewhere that if you use dual carbs then you need to replace the standard fuel pump with a more powerful one preferably located close to the tank, or is that only for high performance applications :zhelp:
:mrgreen:
Been thanked: 487 times
just get a small facet pump and put it near the tank. Not expensive.
Tony Z wrote:just get a small facet pump and put it near the tank. Not expensive.
Spy camera, ... again....... :shock:
You looked under the Fastbacks shirt AGAIN hey, Tony........ :roll:
You got it 1st time, good call Tony. :wink:
OD_1
Oil Seal
Post by OD_1 »
Thanks again guys... will i have to get a fuel regulator as well?
no, facet works at 3,5psi, ideal for carbs
