Help rescue a Bay Camper - please
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Re: Help rescue a Bay Camper - please
That's looking really nice.
I am so glad this Westi was saved, still can't believe someone had taken it for scrap.
- didi
- Has thanked: 9 times
- Been thanked: 37 times
_______
- didi
Working in the moonlight, the canvas is nearly installed.
_______
- didi
I needed to get some metal replaced in the engine bay, which was cut off for the DJ conversion.
I took a day off work on Thursday and went through to Van den Brink to get the 2 pieces that I needed. They could not help me at that stage and said they would phone me back, which they never did.
Out of frustration, I fabricated it myself, and I am happy with the end result. The engine is ready to be installed
_______
- didi
Flower attack! The two ladies in my life got their way
_______
Love it! Made me immediately think of
http://www.youtube.com/watch?v=ttBnNXmO ... FF4946B08F
(Blommetjie gedenk aan my.. )
Not only did you restore a icon, but you also reviving and ERAdidi wrote:Flower attack! The two ladies in my life got their way
Love it, good work.
- didi
Thanks Herman,
I can't wait to put this bus back on the road! Next is the engine. It's built and just needs to go in. Hopefully I can do it tonight.
Pine, I've got the cd. I'm going to play it loud tonight while I'm working on Blommie
_______
- didi
So, I'm putting the engine back and the studs are to short. They don't go through the sleeves on the bellhousing! It's a 002 gearbox with a later type bellhousing. The sleeve on the later gearbox are about 18mm longer.
_______
Are you sure the Clutch plate has been lined up, or that the spigot shaft fits into the engine bush, or the clutch plate spigot splines are incorrect, sounds more like the engine is not fully in......didi wrote:So, I'm putting the engine back and the studs are to short. They don't go through the sleeves on the bellhousing! It's a 002 gearbox with a later type bellhousing. The sleeve on the later gearbox are about 18mm longer.
- didi
I am sure, the rear engine mounts line up as well. I've got a early 002 gearbox in the garage, and I measured the sleeve length. The original bellhousing is 44mm and the later one is 60mm. I'm now worried that the thrust might sit deeper as well on the late bellhousing. It was previously a DJ conversion.
_______
- Been thanked: 321 times
I think the starter is also different. You probably need to find an original early 1600 bellhousing.
I love the progress you're making on this bus. See you at the 2012 KKKult kamp-out! I hope you're still making progress on Norm ...
- didi
You are right Fig, the starter shaft is longer. There is a sleeve before gear.
_______
OHdidi wrote:......... It was previously a DJ conversion.
Think Fig is right...
And a new starter.fig wrote:....You probably need to find an original early 1600 bellhousing.
- didi
I spoke to IMPI and he said that the later bellhousing should work with the type I engine. He is going to give me the longer studs.
One way to find out......
Norm's bodywork should be finished in December. Let's wait and see.
_______
