What part is this?
johanmarais
What model do you have?: 1990
Has thanked: 28 times
What part is this?
Post by johanmarais »
Well after about three years without a bus I purchased myself a 2.1 Caravelle (ok it's not aircooled BUT it's a "bus")
I've been doing some small fixes this week but one of my big problems is that the auto gearbox does not kick back when you put foot in town.
Can someone maybe tell me if this part is "part" of the kick down system?
1990 2.1 Caravelle (Auto)
Has thanked: 221 times
Been thanked: 226 times
Re: What part is this?
I do not know about a Microbus auto gearbox, but the automatic 411 and 412 Variants had a microswitch below the accelerator pedal, if you would 'floor' it it would close the circuit for a solenoid on the gearbox to select a lower gear.
Perhaps the Microbus has a vacuum-based system?
Has thanked: 224 times
Been thanked: 455 times
That looks to be a vacuum kick down and will pull a link in the gearbox to allow the box to kick down.
If you floor the petrol, you cause a high vacuum, and this will tell the box to step down one or more gears.
1952 Split Beetle 1835cc (Azure Blue)
1968 Fastback 2Lt.type4( Red)
1972 Low Light Bay Panel Van 2Lt type 4(White)
1975 Fleetline Panel Van 1914cc (Aqua Blue/White)
2019 MeFusco Beetle Truck
johanmarais
Thanks Herman. So I take it that the cable should not be loose then
Without vacuum, it should be not pulling, but all slack taken up.
johanmarais
ah..... just took out the slack and it works a charm.... Thanks Herman
Another thing sorted.
