Semaphore bus with Std "Flashing Front Blinkers"
Jdt1976
Has thanked: 98 times
Been thanked: 83 times
Post by Jdt1976 »
Have any of you seen a semaphore bus with front indicators?
On my Feb 58 bus the one M-code (on the Birth Certificate) it shows M-code:164: "Flashing front blinkers"
I tried to search on the Samba but did not fiend anything so far. On the M-code page on the Samba it is mentioned: "seen on a 57 kombi"
What type of lights would it be?
I am not sure if it is correct but there are holes that doesn't look like its been drilled afterwards, so there might have been some factory fitted indicators on?
Does anyone have some info on that?
Here is a pic of the L & R side holes.
Has thanked: 224 times
Been thanked: 455 times
Re: Semaphore bus with Std "Flashing Front Blinkers"
I read somewhere that the VW's that went to USA had to have Indicators fitted from May 1955
The Dealers fitted them, till the bodys could be changed, and then they came from the factory fitted with them.
Many different types where used, but the most used where the base plate type such as these... http://www.autocrafteng.co.uk/shop/spli ... 55-63_909/
Well that all I remember, and also not sure if I remembered it correctly.
1952 Split Beetle 1835cc (Azure Blue)
1968 Fastback 2Lt.type4( Red)
1972 Low Light Bay Panel Van 2Lt type 4(White)
1975 Fleetline Panel Van 1914cc (Aqua Blue/White)
2019 MeFusco Beetle Truck
