Air Filter
Batman
What model do you have?: 1971 Beetle 1600 TP
Air Filter
Post by Batman »
Hi guys ...
I'm busy restoring my air filter.
As can see on the picture there is a pipe from the air filter to the vacuum port. I don't have a vacuum port as indicated ... where should that pipe go in that case ?
Riaan.N
Re: Air Filter
Post by Riaan.N »
My intake manifold also doesn’t have one and I also don’t have the thermostat anymore. On mine, those 2 ports on the air filter box is blocked off...a tube runs from the one to the other.
Batman
Re: Air Filter
Post by Batman »
Riaan.N wrote:
Thu Mar 07, 2019 1:31 pm
Thanks Riaan, that is how it was ... just a pipe from one to the other. Just wanted to have everything stock again.
