Hi Guys.
Since Monday, my ignition light glows when I remove the key and the battery is not charging.
I have replaced the regulator with a new one but the problem persists.
Where do I look now?
Cheers
David
Alternator external regulator
- Oil Seal
- Has thanked: 13 times
- Been thanked: 9 times
Re: Alternator external regulator
Is it wired properly, maybe its best to seek an auto electriciandkjinsa wrote:Hi Guys.
Cheers
David
Sent from my FIG-LX1 using Tapatalk
- Has thanked: 191 times
I think you have an earth fault somewhere that you need to find
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
If the light comes on when you switch the car off, you may have blown diodes inside your alternator
- What model do you have?: 1974 Beetle
Thanks guys.
I had an internal regulator alternator on the shelf which I thought was FUBAR.
Gave it a good internal dusting, fitted it to my engine and it works fine.
I'll take the old one to an auto electrician and let them sort it out. It is nice to have a spare.
