type 4 engine number
Posted: Sat Apr 20, 2019 9:09 am
by sarel marais
Morning all. I can buy engine 2l type 4 for spares. Engine number SFCUR204927 This must be a CU cu engine aircool. Why all the other letters ? Can somebody help ? I Think this engine came out of t25 or t3. Can this be a 2.5 Aircool ? My number 083 337 3377 Sarel
Re: type 4 engine number
Posted: Sat Apr 20, 2019 3:01 pm
by sean
Hi Sarel
SF means the engine has been rebuild. It would have originally only started with CU.
You are correct about this being from a T3. It can not be 2.5L, only 2L.
I see in your profile that you have a 72 baywindow?
This engine is incorrect for a baywindow, unless you love angle grinders and welders.
All the ancillaries on the motor does not fit, including the flywheel inside the gearbox.
Being a 72 model, it should be a 1700 type 4 motor if in a bus or a 1600 type 1 motor if its a commercial vehicle or standard kombi.
Posted: Tue Apr 23, 2019 5:27 pm
by fig
Actually SF says it was built in the VWSA Uitenhage factory.
R says it had a case replacement.
Rebuilds usually just had the VW exchange logo after the engine number.
