Engine Number
- What model do you have?: JEEP (Veep)
Engine Number
Good day who can help me can't seem to work out my Engine Number!
Found that its n 1600 but can't seem to now the rest.
Found charts that can help you, but don't seem to find the Engine number that a have?
6FA S399400
Help
Thank You
6FA S399400
Help
Thank You
- dixtoy
- Has thanked: 60 times
- Been thanked: 37 times
Re: Engine Number
It wil be SF AS
1959 Beetle (Lindor)
1975 Fleetline panel (Ouvrou)
1971 Westy (Gypsy)
1971 Westy (Gypsy)
Re: Engine Number
It realy looks like n 6!!
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
Re: Engine Number
As quoted by @Fig in anothet post
"SF is the prefix for South African built engines"
- dixtoy
Re: Engine Number
AS is a replacement Case, the only way to really know what size engine you have is to remove one head and measure bore and stroke.
1971 Westy (Gypsy)
1971 Westy (Gypsy)
Re: Engine Number
DAM!!!
Can you PLS help me on the chassis number??
SE 111 2 301 144
SE 111 2 301 144
- Herbie
- What model do you have?: 1978 Beetle SP 1600
- Has thanked: 9 times
- Been thanked: 35 times
Re: Engine Number
Not a fundi but here goes
1 - type 1 (beetle)
1- sedan
1- 1971
2- means manufactured post 1970
301144- allocated chassis sequence number
Vehicle manufactured in Oct 1970 which would make it a 1971 production year
Neels
Neels
1 - type 1 (beetle)
1- sedan
1- 1971
Neels
Neels
Blood Type: VW+
1978 Beetle SP 1600
1963 Beetle
1978 Beetle SP 1600
1963 Beetle
Re: Engine Number
So the second 1 means its n sedan
So the firts 1 is type that is beetle
The second 1 means its a sedan and not on vw beetle
now im lost
now im lost
Re: Engine Number
beetle is a sedan, this means car, as in not truck, or commercial.
- Herbie
Engine Number
The second 1 says it is a sedan and not a convertible... so first 1 says it’s a beetle and second 1 it is a beetle sedan, not convertible or station wagon or fastback ( not that there was other kinds of beetles but those codes applicable to type 3 and 4 for example)
Neels
Neels
Blood Type: VW+
1978 Beetle SP 1600
1963 Beetle
1978 Beetle SP 1600
1963 Beetle
Re: Engine Number
What beetle was built with two weber carbs (32 idf 40 oc)
What cc was it build in?
What year model?
Can some one help on this??
What year model?
- Been thanked: 321 times
Re: Engine Number
Weber carbs were never fitted as standard on ACVWs.
Re: Engine Number
Think he is talking about the twin solex, on the SP 1600 Beetle in the last few years.
