ALIGN BORE
Posted: Wed Jul 22, 2020 9:22 pm
by Cyndi Kritzinger
I HAVE THE NEED TO FIND SOMEONE WHO DOES ALIGN BORING (WELL) AND IS REASONABLY PRICED. I'M LOOKING AT HAVING BOTH 1600 AND 2L ENGINES DONE.
ANYONE KNOW OF A REPUTABLE PERSON/BUSINESS.
EVEN BETTER IF THEY CAN ALSO SUPPLY THE BEARINGS.
MARK
Re: ALIGN BORE
Posted: Wed Jul 22, 2020 10:06 pm
by Blitzkrieg
Impi
All can do it
Re: ALIGN BORE
Posted: Thu Jul 23, 2020 1:26 am
Bugger bought Impi's kit
I can linebore T1's but only up to 1.5mm
and I'm currently out the country until Nov (hopefully I can get back...)
Re: ALIGN BORE
Posted: Thu Jul 23, 2020 9:50 am
by Haans
There's a guy in PE if you want me to get further details
Regards Haans
Re: ALIGN BORE
Posted: Thu Jul 23, 2020 8:23 pm
by Cyndi Kritzinger
HOWDY HAANS.
THANKS BUT HOLD YOUR HORSES FOR NOW. I'VE GOT A FEW QUOTES SO FAR AND WAITING FOR A COUPLE MORE.
IF I'M NOT HAPPY I'LL GET IN TOUCH WITH YOU.
@ TONY....
LOOKING TO DO MAINLY 2L RIGHT NOW BUT WILL STAY IN TOUCH RE: 1600'S
HEY BLITZ.
I HAVE HAD SOME FEEDBACK FROM THOSE MENTIONED. THANKS FOR THE HEADS UP THOUGH.
Re: ALIGN BORE
Posted: Thu Jul 23, 2020 8:31 pm
by Cyndi Kritzinger
HOW ABOUT 2L MAIN BEARINGS?
Re: ALIGN BORE
Posted: Thu Jul 23, 2020 9:02 pm
Alert engine spares,
Boss auto spares
Volkspares
Re: ALIGN BORE
Posted: Fri Jul 24, 2020 6:35 am
by buggyfan
buggyfan wrote: ↑Tue Apr 18, 2017 2:48 pm
Went to a shop in Mooi str Jhb and they had all different sizes O.d /i.d bearings.Mostly smagon brand.According to the guy behind the till he can get any size fot tipe1 aswell as tipe4 engines.They supply Bruce in Horizon that does the line-boring with all his parts.
Details
Swag n tail V.W motor spares .011 3345973/0113341470
Jerome 0721269990
Re: ALIGN BORE
Posted: Fri Jul 24, 2020 6:43 am
by buggyfan
For align bore you can also try Bruce
Bruce 084 502 1099, Horizon, Roodepoort
Re: ALIGN BORE
Posted: Sat Jul 25, 2020 3:21 pm
by Terry Phillips
why do you want to line bore the blocks, did they run main bearings ?
Re: ALIGN BORE
Posted: Sat Jul 25, 2020 3:38 pm
by Cyndi Kritzinger
THESE ARE ALL OLD BITS OF ENGINE THAT A FRIEND OF MINE GOT WHEN HE BOUGHT A BUS IN CPT.
MOST OF THE STUFF IS TOAST. THE ONE BLOCK IN PARTICULAR HAS SOME ISSUES WITH THE BEARING AND BLOCK BEEN PINHOLED (I BELIEVE TO TRY AND STOP THE BEARING FROM SPINNING). THE CAMSHAFT GEAR WAS BUSTED RIGHT OFF THE SHAFT ON ONE ENGINE AND THE HEAD AND SLEEVE ON ONE WAS SO THICK WITH RUST IT LOOKED LIKE A PACKET OF STRAIGHT CUT SIMBA CHIPS INSIDE.
I AM JUST TRYING TO USE WHAT I HAVE TO MAKE UP SOMETHING THAT'S GOING TO WORK.
@BUGGYFAN
THANKS FOR THAT INFO. I WILL GIVE THEM BOTH A SHOUT.
Re: ALIGN BORE
Posted: Fri Jul 31, 2020 8:57 pm
by Bugger
Tony Z wrote:Bugger bought Impi's kit
Don't know where previous post have gone
No we did not buy IMPI S MACHINE
we bough from other supier
IMPI still got his
