VDO Revcounter for SP Beetle and other.
Technical diagrams & drawings
Tom Bishop
Post by Tom Bishop »
Hope this helps someone. For everyone that uses this VW/VDO revcounter diagram, the charge is one beer.
Re: VDO Revcounter for SP Beetle and other.
OK Tom, I owe you a beer. I'll owe you 2 if you can make a simpler drawing of how to connect a rev counter.
Tom Bishop
Ill make it more simple.
Just bring your car and rev counter over to my shop and we will get it going. Easier for me to do than to write.
But I hope you are not wanting to fit one to your beetle.
lol. I'll bring it tommorrow with the clock.
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
Bump 4 beetle768
beetle786
Camshaft
Post by beetle786 »
buggyfan wrote:Bump 4 beetle768
:lol:
beetle 786
thanks
4029
buggyfan
Long Block
Post by buggyfan »
No need to thank me, just send Tom Bishop his beer :drunks: :drunks: LoL!!!!!!!
beetle786
Camshaft
Post by beetle786 »
you send to him on my behalf ,don't handle beer :shock: sorry .
will post a cool pic of the rev counter when i get it working :D
4029
beetle786
Camshaft
Post by beetle786 »
Thanks Tom know you like pics don't handle beer .
will put up lots of pics when i get the tacho working :mrgreen:
4029
Donovan D
Has thanked: 148 times
Been thanked: 73 times
Post by Donovan D »
Tom Bishop wrote: Image
Why can't I see this pic ?
I want to know how to connect one of these.
Has thanked: 45 times
Been thanked: 208 times
Difference between VDO -"SP", and universal VDO revcounter:
Typical VDO universal revcounters, (not "S.P".), are "voltage sensing". Separate wire needed from points to gauge. Sensing voltage swings between 12V and chassis when points switches. Typically senses terminal marked "1" on coil. Some electronic modules have dedicated output pin that triggers revcounter. Some newer types intended for diesels senses alternator pulses.
"VDO SP revcounter": Current sensing. Positive black wire from ignition switch goes to terminal marked "+" on revcounter. Terminal marked "15" on revcounter goes to coil terminal 15. Terminal marked "-12V" on revcounter goes to chassis earth.
(Designed so that no extra wire is needed to the back. Current from ignition switch, (black wire), simply passes in series through revcounter on it's way to the +/ terminal "15" on the coil. Via existing black wire.)
Similar system were used by some other makes like Smiths.
Donovan D
Post by Donovan D »
Great, thanks Dawie !!
buggyfan
Long Block
Post by buggyfan »
Donovan D wrote: Sat Apr 11, 2015 4:56 pm
Camshaft
Been thanked: 107 times
Post by Haans »
Buggyfan,.....I've stopped asking,......it seems that this imagebum thinghamajik is bust!
If you get some image from someone,...I'd like to get a copy of it too please
Regards Haans
buggyfan
Long Block
Post by buggyfan »
