Fastback cooling
Technical diagrams & drawings
Has thanked: 235 times
Fastback cooling
This interesting pic shows how the Fastback gets its fresh air to the engine
after it is sucked in through the side vents
vader
Post by vader »
That is a good pic I'm starting to like fasties more and more./..
vader wrote:That is a good pic I'm starting to like fasties more and more./..
:D :D :D
That might help owners understand why it is important to keep the sealing between the wheelcavity and body panel intact.... otherwise you get road dirt and dust sucked through your cooling fan and blown over your engine and oil cooler :)
Typ_315
What model do you have?: Notch
Re: Fastback cooling
Post by Typ_315 »
Hi there,
Does anyone know where that bodyshell photo was taken? I am looking for a restoratiomn shop, so any help would be much appreciated.
Thanks,
Paul
ZeroAxe
Drive Train
Post by ZeroAxe »
Also, important to note is the extra corrosion coating in that area. Due to obvious reasons of all rain/humidity taken in there....
VW Enthusiast
