Adjustable back Beetle spring plate sets
As some of you guys know I am busy with the Adjustable straight axle conversion kit for Split window bus
I am going to make a set or 2 of the Beetle Adjustable spring plates,so no more beetles hanging on the one side when dropped, now you can adjust both sides 100% by adjusting the spring plate adjusting screw
I had a imported set Chemically analogized and now know what is the right steel to use
Will there be guys that will be interested in Acquiring a set of them for your beetle ??
Hloni
Has thanked: 14 times
Re: Adjustable back Beetle spring plate sets
Post by Hloni »
Super keen on a set or two. How effective will they be for raising for better ground clearance and fitting 4x4 tyres?
3011
BARON
Post by BARON »
Will it be posible to widen the rear track more than just the beatle width. I need to fill a Porsche 930 rear fender with either a very wide wheel or a wide suspension and a normal wheel.
cheers baron
Hloni you will be able to fine adjust the left and right side to precise level
It will be the same as std spring plates just adjustable to a few degrees to lower and raise the bug with out stripping everything out and pulling the torsion bars
out every time you want to adjust
The adjustment should give you about 2 1/2 inches up and down
Baron the easiest will most probably be to make ally spacers to bring the wheels out
To lengthen the Axles is possible and axle tubes but will be Quite a expensive Exercise, We can use 2 sets of axles and get them cut and spline d joined to lengthen them but How strong that will be is another Question
slak
Has thanked: 7 times
Been thanked: 32 times
Post by slak »
What would the price range of a set of these be +-
U Only Live Once Right !!!
slak wrote:What would the price range of a set of these be +-
+-R2500
Need proof that they gonna work first - sorry.
Hloni, maybe your bug can be the guinea pig :D
hitlers revenge wrote:Need proof that they gonna work first - sorry.
These will be a Direct copy of the Kits sold in the USA
I had the Materials Chemically tested to be 100% on using the right material for the job
So This will work no douth
Stütz
Been thanked: 19 times
Post by Stütz »
Pierre, did you ever make a set of adjustable spring plates? Looking for some on my 1974 standard Beetle. PM me if you have a set available. I am assuming that they will fit a '62 as well?
3104
Stütz wrote:Pierre, did you ever make a set of adjustable spring plates? Looking for some on my 1974 standard Beetle. PM me if you have a set available. I am assuming that they will fit a '62 as well?
I did make 2 sets but the splinning was wrong and I am still waiting on the guy now to rectify them
Stütz
Post by Stütz »
Cool. We'll chat once you are happy that everything is correct.
3104
