1972 Crossover D/C - Blue Abomination
freddiebooysen
What model do you have?: 1972
Been thanked: 46 times
Post by freddiebooysen »
Any idea where I can get them locally? Or is it import only as previously mentioned Sean ?
Has thanked: 226 times
Been thanked: 458 times
Re: 1972 Crossover D/C - Blue Abomination
Here you are , good discount price for the real thing.
https://www.ebay.co.uk/itm/VW-Transport ... 1447706753
Or you can run the ones you got till they die, which could be 20 years from now, only by torquing the bolts with a bit of loctite thread loc.
Just remember to jack the back end up to get both wheels off the ground BEFORE fitting the clamps on your booths,
or they will tear on the 1st speed bump, this happens to the OEM booths as well.
OMO
1968 Fastback 2Lt.type4( Red)
2019 MeFusco Beetle Truck
freddiebooysen
Will do Herman thanks.
Freddie Booysen
Jdt1976
Has thanked: 98 times
Been thanked: 83 times
Post by Jdt1976 »
Freddie, just for interest, I bought some OEM boots from VW Classic Parts (Part number 211 598 201) but they are just later productions.
The ones that came with the Lobro (GKN Automotive) sets were just as good if not better.
Check with Sean where he buys the Lobro ones local. To give you an indication, I paid 106 Euros for the Lobro kits when I imported them,
but heard afterwards one can get them local.
freddiebooysen
Thank You
Freddie Booysen
