Should work fine, saw one on e-bay really cheap, I was thinking of getting an electric pump caravanners use, pumps at about 1-1.5 bar for about R 900.00, not sure if it would last though, could do if I only swith the fan and pump on while boosting. Bought an electric waterpump from Goldwagen, doesn't displace nearly enough water though. Will use it to circulate rad water after shut off now.4agedub wrote:Thanks
Idealy I would like to get a water pump from a toyota celica st205.
Beetle type 4 twin turbo project
- Bratjie
- What model do you have?: 74
- Facebook: https://www.facebook.com/juan.buter
- Has thanked: 3 times
- Been thanked: 5 times
Re: Beetle type 4 twin turbo project
Esté robusto, ser fuerte!!!!
73 Beetle project
73 Beetle project
- 4agedub
- Has thanked: 4 times
I think you want the pump to run permanently, there is no use in only circulating under boost. Besides the Toyota water pump, I have found a universal one locally for R1200.00.... I'm still in two minds about buying it or trying to get one from a toyota
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
- Has thanked: 36 times
- Been thanked: 50 times
- 4agedub
It's manufactured in china available from Mr turbo
Bit of a luck shoot on it then.....some are better than the others..any guarantee on it?
Any ideas as to what the OEM price is? Maybe have a check on E-Gay to get an idea of overseas pricing....
- Has thanked: 191 times
If you are looking for 12VDC water pumps, go to the yacht/boat shops and see what they have from either Jabsco or Johnson.
They may not be cheap, but they are good.
- vader
- Has thanked: 9 times
And people wonder why Angerrrrrr costs so much!!! That project has more maren equipment on it than the Titanic....
- Bratjie
Googled those pumps and other marine pumps, some only good to about 80 - 90 deg, best bet I think is the Toyota pump or the one from MR T.Tony Z wrote:If you are looking for 12VDC water pumps, go to the yacht/boat shops and see what they have from either Jabsco or Johnson.
What are you planning to use for water pipes, radiator and location, header tank, thermo switches etc?
73 Beetle project
73 Beetle project
- 4agedub
Normal rubber hoses from the rear to the radiator in front. One pump and one header tank with a big enough hole so I can chuck ice into the can. No thermo switch, let it run permanently.
- Bratjie
Cool, cant wait to see your progress on the build, I'm busy mocking stuff up to put the 1.9 wbx Turbo in the Beetle, you're a real inspiration man.
73 Beetle project
73 Beetle project
- 4agedub
Ok, nothing has happened this past week.
The red beetle has taken up most of my time to prep for this year's racing.
New H-beam front suspension installed, next up set up camber and toe and then a full service. Maybe by end of next week I can spend some time on the twin turbo setup again.
- 4agedub
Some progress again
And I found a good water pump for the intercoolers You do not have the required permissions to view the files attached to this post.
- 4agedub
- slak
- Has thanked: 7 times
- Been thanked: 32 times
A 4 wheeled DEMON wow that is some great plumbing work there
U Only Live Once Right !!!
- Bratjie
What pump is that 4age? Any specs?
73 Beetle project
73 Beetle project
