Rear suspension adjust
- Ron&Gill
- Been thanked: 21 times
Re: Rear suspension adjust
I looked for posts but I can't find anything about your engine... what did you do to it?
- hitlers revenge
- Been thanked: 36 times
It was a big secret. I don't think anybody knew.
Loopy kept it very hush, hush.
- Loopy
- Has thanked: 11 times
- Been thanked: 6 times
My engine was the small project that Tony was working on during his last shore leave, need to make a new post on it or update my buggy fixer-up post with the newest (and some not so new) changes made to the buggy. What I can say is that this might be able to convey my feelings
Thanks as well to HR for his time that he offered up getting the suspension in order
- Ron&Gill
So what all did Loopy do to crack his poker face into a grin?
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
Thread Resurrection required..
@ loopy and HR, I need some clarity on this please. I'm in the situation where I need to perform this adjustement in the next couple of days. The Speedy sits a tad too high at the rear, I'd say it's 3 to 4 cm's. I am keen to try and do this myself, and have all the tools, however, from what I've seen on Youtube etc, it doesn't look very convincingly simple, and looks as if it's very easy to mis position the splines going back in, and then you end up with the setup being uneven, or lop-sided.
Was your process as follows. Once the sideshaft was off and the plate cover off, you jack up the spring plate to control it's "loaded tension", then pry it off the lip and gently lower the jack till it's "at rest". When are you measuring those angles? While it's all still connected and "sprung"?
Looking forward to your suggestions and comments please chaps.
Also, Why did you buy bushes? Are they required to be replaced when you adjust the Plates angle?
Pls elaborate a little more gents.
thanks in advance
regards
Alan
thanks in advance
regards
Alan
- Gerlach
- What model do you have?: 1976 Type 1 beetle
- Has thanked: 9 times
- Been thanked: 4 times
acpaterson wrote:Thread Resurrection required..
Ek het destyds vir my n tool gemaak om te help om die "plates" af te kry onder toe. Ek het so bietjie nare stories gehoor van wat daai spring plates los kom op jaks, dan slaan hy als af wat in sy pat is. ek moet eintlik kyk waar die tool is en dit post. maklik entlik om te maak, en dan weet jy doen als veilig. Ek het adjustable spring plates op my beetle.
Maak dit makliker om presies te stel die hoogte.
Goeie tip wat ek jou kan gee, kry n correction pen en maak merkies op die sideshaft en spring plate, dit maak dit makliker vir jou as jy jou oues gaan gebruik, dan kan jy sien hoeveel jy geskywe het. Laat weet as jy sukkel.
thanks in advance
regards
Alan
- Loopy
Alan
We used a length of chain looped around the shock tower and the jack, which made the process more controllable.
Angles was measured with the spring plate in a relaxed state. The bushes was slightly worn, so I used the opportunity to replace them while everything was disassembled.
Make certain that whatever you use to measure the angles, is of a good quality. The one I used gave me issues, so I ended up using an app on my phone (Protractor + Angle Gauge Free on Android). The buggy was standing on 4 axle stands, so that it was level all around. You will need to play around with the inner and outer splines to get the two sides as close as possible to each other.
Regards
Robert
Regards
Robert
- What model do you have?: 1982
Stupid question, my beach buggy while driving, both rear wheels go into a negative camber, looks like i have a huge load on the rear, but its just me in the buggy. Any advice to a rookie as to where to set the camber right or tighten it? Ive looked and i am battling to see where
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
You have to remove your trailing arms and re-index the splines on your torsion tubes. Quite a tricky operation to get it right.
