1970 Baywindow Bus
- sean
- Has thanked: 63 times
- Been thanked: 227 times
1970 Baywindow Bus
It seems the projects have been a little quite on the forum lately.
Here is one I have been busy with.
Its one the last buses I collected from Mark in Barrydale. It was a unfinished project. It had been finished up until primer, but wasn't the most fantastic job. The interior was also missing. I made a start on this one first as a lot of the work was already done and in the rebuild process, so was the obvious choice before tackling a bus that was in an original driving state.
Here are a few pics from when it was taken away.
I had taken care of the sandblasting of the rusty areas and the metal work where needed. The bus has had a few bumps and scratches in its life, a few rusty spots in the usual places, but otherwise quite solid. I then handed it over to a panel beater to do the final preparation and top coat.
The colour is a standard 1970 SA bus colour called Java green.
- sean
Re: 1970 Baywindow Bus
Last weekend I started on the mechanical components. The gearbox I simply cleaned up on the outside. The motor is a freshly rebuild 1600 single port with generator.
Being on my own, I was lazy to remove that engine off the table, so I rather just put the engine and gearbox in the bus in one shot on the table and under the lift. It worked pretty well actually and I didnt have to pick up anything heavy.
More to follow later.
- Eugene
- Has thanked: 59 times
- Been thanked: 65 times
Love the colour Sean....would look killer with black or white interior
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
Good going there Sean !
Did you just use a jet wash for the outside of the gearbox ?
- sean
No, it was quite a hideous long process of using a wire brush on a pencil grinder to clean it up. I think it swallowed 3 of those brush wheels in the process.
- sean
The interior is going to be black. Black basket weave vinyl for the seats, off white perforated vinyl for the roof lining and I have some original door panels which were that light grey and dark grey combination.
- fourier
- Oil Cooler
- Has thanked: 31 times
- Been thanked: 37 times
Another awesome bus. Well done Sean! Very nice colour combination.
(o= i =o) (o\ ! /o)
- Jdt1976
- What model do you have?: 1952 beetle
- Has thanked: 114 times
- Been thanked: 90 times
Agree, it is looking good.
It was discussed before but cannot remember, was the local Java green the same as the German colour?
- sean
No, not the same. I had the paint mixed from a SA sample Java green. In 1969 it was called Java green and in 1970 the name changed to just Dark Green, but both look the same.
- AlanH
- Has thanked: 117 times
- Been thanked: 86 times
Looking good.
Where are you getting the upholstery from?
TMI?
TMI?
Wanted parts:
Left sunvisor
Sink faucet
Left sunvisor
Sink faucet
- sean
- Has thanked: 193 times
- Been thanked: 121 times
Very nice Sean the production line looks busy, are you on night shift hehe. Nice work.
- Been thanked: 539 times
Nice work Sean, looks like you will be giving Gerhard from Bloem a run for his money with regard to number of Aircooleds, ....or should I say VW Buses.
