"Eva-Ann"
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Re: "Eva-Ann"
Post by 73type2 »
Nice!!
Batman
What model do you have?: 1971 Beetle 1600 TP
Re: "Eva-Ann"
Post by Batman »
.... washed her last night before the rain
Been thanked: 539 times
Re: "Eva-Ann"
Nice, you should come down to PE and wash all our cars, .... we need lots of rain...
Batman
Re: "Eva-Ann"
Post by Batman »
The previous owner rubberised the interior for some reason. I thought that it was still in a good condition and that I would just clean it out and I would carpet over it.
But the weekend with some closer inspection I realised that it was lifting and that the one door is leaking, causing water to build up between the rubberising and the floor-pan.
Here's some before photos.
Camshaft
Been thanked: 107 times
Re: "Eva-Ann"
Post by Haans »
This is where the fun starts !! Decisions decisions !!!!
Batman
Re: "Eva-Ann"
Post by Batman »
Haans wrote: Mon Dec 10, 2018 8:02 am This is where the fun starts !! Decisions decisions !!!!
Started lifting the rubberising ..... this is not going to be an easy job.
Agree, can't decide on the interior yet.
Camshaft
Re: "Eva-Ann"
Post by Haans »
Try a heat gun to lift the rubberizing,....worked for me
Donovan D
Has thanked: 148 times
Been thanked: 73 times
Re: "Eva-Ann"
Post by Donovan D »
A heat gun should do the trick. There is always some hidden surprises.
Riaan.N
Oil Seal
Has thanked: 3 times
Been thanked: 37 times
Re: "Eva-Ann"
Post by Riaan.N »
One possible reason for the rubberising is that helps with noise isolation. A better approach, in my opinion, would be to install a purpose made noise isolation material like Dynamat (there are probably some other brands as well).
Re: "Eva-Ann"
If you can get dry ice, or Liquid nitrogen, Spread it over the rubberizing and you will hear it crack
Then just lift and remove with a scraper, as it will be loose, wear gloves, or loose you fingers.
73type2
France
Re: "Eva-Ann"
Post by 73type2 »
Pro Auto Rubber is now selling a product which does heat insulation as well as sound deadening, at a fraction of the cost of Dynamat. I've bought some and am very satisfied with it.
64 Notchback
Has thanked: 78 times
Re: "Eva-Ann"
Post by 64 Notchback »
retrovan wrote: Mon Dec 10, 2018 10:20 am If you can get dry ice, or Liquid nitrogen, Spread it over the rubberizing and you will hear it crack
if you go the Dry Ice route then there is a place here in Spartan that sells pellets and blocks of dry ice (Dry Ice Africa)
Camshaft
Re: "Eva-Ann"
Post by Haans »
There's nothing like the day after a couple of blisters and broken skin over the knuckles!!!!😜
It works for a bit of attention from the missus / girlfriend/partner !!😏
Batman
Re: "Eva-Ann"
Post by Batman »
I'm also still in two minds on going imitation leather or material for the interior
73type2
France
Re: "Eva-Ann"
Post by 73type2 »
I'd go marine vinyl. It's more expensive than Kehl's vinyl but stronger and more durable. Also more UV resistant.
