Has thanked: 178 times
Been thanked: 430 times
Flag: Netherlands
Post by retrovan » Mon Jan 28, 2019 11:11 am
Bugger wrote:
Mon Jan 28, 2019 10:58 am
Herman do Any of you guys know where I can get that plate with holes in they use on the car transporters
These are normally only made by an engineering works as they are punched in to give the grip on the wheel side.
You can use expanded mesh as well, you get 3 or 5 mm which is better then the perforated sheets.
1952 Split Beetle 1835cc (Azure Blue)
1968 Fastback 2Lt.type4( Red)
1972 Low Light Bay Panel Van 2Lt type 4(White)
1975 Fleetline Panel Van 1914cc (Aqua Blue/White)
2019 MeFusco Beetle Truck
Riaan.N
Been thanked: 18 times
Flag: South Africa
Post by Riaan.N » Mon Jan 28, 2019 11:45 am
Some cnc cutting and bending places might be able to do it if they have the punching machine with the dies.
Or you can have the plates cnc cut for all the holes and use a dimple die...will take some time and maybe give you some blisters...or just use an air ratchet thingy or a battery operated drill with adjustable torque settings.
Oil Seal
Been thanked: 43 times
Flag: South Africa
Post by Haans » Tue Jan 29, 2019 8:28 pm
If my memory serves me right,.......I think ONVLEE engineering in PE did a similar job for rail car carriers a few years back.
Was punched with a die to make hole and bend the metal around the.hole out,.... hence giving the grip for tyres of cars to be transported.
Hope it helps. Haans
Terry Phillips
Has thanked: 161 times
Been thanked: 110 times
Flag: South Africa
Post by Terry Phillips » Tue Jan 29, 2019 9:47 pm
Andrew Mentis Gauteng they do all that stuff Google them in Elandsfontein .I know Roy Mentis.
Has thanked: 17 times
Flag: South Africa
Post by Bugger » Tue Jan 29, 2019 9:48 pm
Thanks Terry
JonnoDub
Oil Seal
Been thanked: 9 times
Flag: South Africa
Post by JonnoDub » Wed Feb 06, 2019 9:25 pm
Looking good as usual Herman, now that I found this post it gives me a reason to visit this forum more often.
Dont stop now !
Flag: Netherlands
Post by retrovan » Thu Feb 07, 2019 10:50 am
Dont stop now !
Thank you Sir,
Glad it is inspirational, as that is what I have been hoping for.
Did not do much, as far as progress, but due to coastal conditions, I was forced to put time and effort into the flash rust issues.
So yes, did a lot of spray painting, but little construction.
Well suppose that is also part of the project.
Engine cover / Floor board still has to have the stiffener webs welded before priming.
Oil Seal
Flag: South Africa
Post by Haans » Sun Mar 03, 2019 11:11 am
So! Whats happening on this front ? Herman
Flag: Netherlands
Post by retrovan » Sun Mar 03, 2019 4:56 pm
Yes Haans,
life has thrown me a curve ball, so my time is not on the projects
But on the more important things..............
Oil Seal
Flag: South Africa
Post by Haans » Mon Mar 04, 2019 7:28 am
As long as everbody is ok and healthy !
Regards. Haans
Flag: Netherlands
Post by retrovan » Sat Mar 23, 2019 3:30 pm
Sure thanks Haans,
Had to shift the guys up in the bed to get the 3 some in..... :shock:
Not sure when they will come out to play again, but hoping it soon.
After all we do have an invitation to a ball ... :D
Thank goodness its a "come as you are" :evil:
Flag: Netherlands
Post by retrovan » Sun Apr 14, 2019 3:38 pm
So we , well when I say we, its the commoners we, in other words, Me Myself and I, have found some time to get the MeFusco project going again.
Need to style up the front fenders, so I needed two sets of Fenders.
Fortunately I had the flower fenders from this here rusted body, as well as the fenders from my 56 Oval, that I have been accused of fitting to who knows what. but as I have the front and rear fenders from the oval to fit onto the MeFusco, not to mention the bonnets and other parts, it kind of puts pay to the school girl cat-ich jealousy.
As the McPherson struts are in the way for the standard fender, I need to make a double dip fender, to blend in with the rear, normal fender.
As can be seen the mock-up has been made using two fenders, and will now be filled in to complete the shape.
Have also started in completing the engine bay, and completing the boxing so that I may be able to fit the floor.
The floor has the Engine inspection hatch cut out already an will fit into place perfectly.
Made up some seat rails and welded in the adjustment studs, so that the seats slide fully to any position.
Seat rails have been marked and fitted to floor, and now I will be fitting the ovals foot peddles.
This will be a bit complicated as the seat has to be in before the peddles can go in with the steering column, which will also be from the oval.
The steering column will have to be shortened and the internal shaft as well. still need to get a double universal for the shaft.
Oh Well till next time.
Thanks for looking.
AlanH
What model do you have?: '60Beetle, '70Westy
Has thanked: 46 times
Flag: Germany
Post by AlanH » Sun Apr 14, 2019 5:48 pm
Nice going Herman keep it up.
I think it will be a stunner.
Cyndi Kritzinger
Facebook: yes
Been thanked: 59 times
Flag: South Africa
Post by Cyndi Kritzinger » Sun Apr 14, 2019 6:23 pm
I'M WITH YOU ALAN.
I'LL MAKE A PLAN TO GET TO J-BAY TO HAVE A SPIN IN THAT MACHINE ONCE COMPLETED.
I'M DEAD KEEN ON CRAZY STUFF LIKE THAT. KEEP IT UP HERMAN!
Terry Phillips
Flag: South Africa
Post by Terry Phillips » Sun Apr 14, 2019 8:03 pm
Herman you best keep going on that project you know old age catches up to you quickly when you having fun.Good to see your commitment on a large project like that.Keep the pictures rolling in love projects that require thought and vision.
