High compresion ???
Come talk £%$ with us.
Been thanked: 539 times
High compresion ???
Hi Guys,
This is totally off the wall, But have never got this issue in all my years.
Have a 6Hp generator, that has run for 5 years or so, no problem.
Now all of a sudden, it has developed excessive high compression , so much so that you break the pull string trying to start it.
When she gets to TDC its as if she has a fuel lock, ie, as if the chamber is full of fuel.
Full lock, but if you keep tension on the rope, she slowly goes through compression and turns freely again.
When you remove the spark plug she runs freely, and nothing is ejected out the plug hole.
Now you may say she has per-ignition, but this happens even when ignition is switched off with no spark.
Even removing the plug lead, she still does this.
Now I have removed the rope pull starter and when fitting a drill and socket she spins and starts no problem.
Yes a bit of a jerk on the arms but she runs.
Now you may think that after running for 10 min or so she would be easy to start as its got the "Fuel Lock" out of its chamber, but no
She has this same problem the sec you stop her again.
Any ideas ........ :huh: :wtf:
Been thanked: 321 times
Re: High compresion ???
Excessive carbon build-up in cylinder?
fig wrote: Wed Mar 11, 2020 10:52 am Excessive carbon build-up in cylinder?
That is an option, thanks Fig, will strip and look after load shedding.....
Has thanked: 191 times
Been thanked: 487 times
sounds like your pull start mechanism is giving you trouble
Tony Z wrote: Wed Mar 11, 2020 12:17 pm sounds like your pull start mechanism is giving you trouble
No Tony, the motor turns over effortless when plug is out, but with plug in, the motor comes to dead stop on compression stroke and due to you pulling hard, the rope breaks.
But yes its like a dead stop. not sure if you ever had a liquid lock in a engine, but that is what it feels like.
If turned by drill it jerks in you hand badly but gets past TDC and starts and runs perfect.
No noise or any problem of sorts.
Camshaft
Been thanked: 107 times
Post by Haans »
Brake fluid whilst running ?? Heard that from you ??
did you recently change the plug? Maybe the one you put in is too long?
Nothing changed, all is still as it was over the years, when she runs she runs good, but to get her over that bump, with the pull rope is impossible where as in the past you lazily extended your arm and she starts.
@ Haans yes that is one of my remedy's for carbon, and yes I will be trying it one evening when there is nobody around in this here stuck up complex......... :roll:
Why I hear some of you ask, well she smokes like a steam train when you burn brake fluid.... :shock:
Camshaft
Post by Haans »
Make the missus goes a visting !,😆🤣😂
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Herman you get 2 types of short plugs there is an extra short plug that is used on small plant engines.
Just try screw your one out half a turn at a time until it turns over. :idea:
