Fiat 126p - Aircooled 650cc 2 cylinder
Re: Fiat 126p - Aircooled 650cc 2 cylinder
Got a video of the clutch action... nice to have a cover that you can remove to reveal the secrets...
Crappy video with my phone but it gives you an idea of how the Reece-Fish operates.
Working on a "rough" test manifold to try out the carb. There might be an issue clearing the ignition leads....
...& yes... I know the flanges are too thin.. I'm kind of limited to using a grinder, hacksaw, drill stand and grinding stones to make stuff but once this works I might make it more sturdy. ;D
I would need to support the carb anyway.
Need to figure linkage, support and leads out...
YAY! I didn't adjust anything yet... but it works niiccee.....
Remember this carb doesn't have any jets. Adjustments are a air bypass, throttle butterfly position and WOT enrichment screw...
What do you guys think?
Next thing is to make it permanent.
No flat-spots like with the 28IMB Weber.....
Retrobug
Has thanked: 15 times
Been thanked: 32 times
Post by Retrobug »
Looks cool! 8)
What are the plans for the air filter?
Hope it's something period looking! :hangloose:
It would have had a trumpet and pancake originally... don't know if that will fit...
Been thanked: 21 times
Post by Ron&Gill »
Ag, nee, foei, dit lyk alles dan so mooi, en dan? Dan jy weld nes ek! :lol:
Hahaha ja Ron maar ons is mos nie skaam nie...
Has thanked: 254 times
Been thanked: 481 times
Eben, have you had the fiat on a fuel analyser yet, is the fuel mixture correct through the full rev range??
That carb is more simpler then the Webers, but look and sound great,.
I think we should all go that way. it they correct. what is your fuel economy compared to the original carb.?
1952 Split Beetle 1835cc (Azure Blue)
1968 Fastback 2Lt.type4( Red)
1972 Low Light Bay Panel Van 2Lt type 4(White)
1975 Fleetline Panel Van 1914cc (Aqua Blue/White)
2019 MeFusco Beetle Truck
Hi, no no tuning yet. I will start the rough tuning this weekend and maybe use a colortune later. This Carb has an interesting tuning procedure.
eben wrote:Hi, no no tuning yet. I will start the rough tuning this weekend and maybe use a colortune later. This Carb has an interesting tuning procedure.
Interested to hear the result, and maybe post the tuning procedure, would be interesting.
It involves odd-sized allen keys, a ballpoint pen, running the engine at 2000rpm, adjusting the position of the butterfly on the shaft for max intake vacuum and running the engine at full throttle for peak power delivery. :)
Still have vacuum leaks...
