Thanks to all who encouraged and kicked my rear end!!! To get to this stage!,
Still have small issues that crop up ,... but other than that Haans is going well.
There is a 356 coupe replica under a cover......screaming for attention!!!! Will remove the cover on saturday and sit next to it and plan!!
Regards to all
Nick
'60 ghia >Haans
- Been thanked: 541 times
Re: '60 ghia >Haans
Nick, you may have to fit a lock to your garage, Haans is running around with other bad influences.
Bunch of Hot Rods ..no less ...
- Camshaft
- Been thanked: 107 times
Re: '60 ghia >Haans
I believe so !!!! Cannot deny or confirm anything !!! Did someone send a pigeon ???
,..all I can tell is that I went to buy bread and the paper !!
Re: '60 ghia >Haans
Its so frustrating that you can not get bread anywhere and you need to drive for 100 Km to get one,Haans wrote: Mon May 25, 2020 9:55 am ...........all I can tell is that I went to buy bread and the paper !!
...and you need an escort to protect you and your car...
We all understand.
- Camshaft
Re: '60 ghia >Haans
Jip had quite an escourt,........ never asked for any assistance to find the "right" loaf !!
But it was nice!
Lost an exhaust pipe,......recoverd !!,....one of the "escourts "( little F word) had a nut or washer dropping into engine from aircleaner. resulting in a nasty noise from within!!
Other than that I arrived safely back home with a nice loaf and the correct paper!!!
Re: '60 ghia >Haans
as you said you do not have much space in Haans,
here is the next project to rectify that
- Camshaft
Re: '60 ghia >Haans
Jip ,.....and add some prize money to my head,....as I believe I will be hunted down for killing a ghia
Beautiful !,
Beautiful !,
Re: '60 ghia >Haans
Would never ask you to do that, that would not be nice...Haans wrote: Tue Mar 23, 2021 8:43 am .............. I will be hunted down for killing a ghia ......
A man of your many talents would highly polish his own Ghia, and pull a mould off the back end,
just past the wheels, and then cast two half's and join them together.
I would even join them in the mould, and make it seamless.
And 'voilΓ ' you have a trailer
You can also make more and sell them...........
- Camshaft
Re: '60 ghia >Haans
Can see the pic,... you've set off some "neurons" that could be dangerous !
