My Daughters ride
mcg
What model do you have?: 69 vw beetle
Re: My Daughters ride
Post by mcg »
Busy busy weekend
finished sound proofing
2lt tectyl diesel and paraffin mix sprayed
in every nic and corner
boot and engine rubbers fitted
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
Looking good Terry !
freddiebooysen
What model do you have?: 1972
Been thanked: 47 times
Post by freddiebooysen »
Really looking good !
72 - Freddie Booysen
72 Bay - unnamed WIP
72 D/C - Blue abomination!
74 Beetle - BEE
mcg
Post by mcg »
so the hood lining is in
doors in windows fitted one small problem
drivers door winder is gestrip (any one got a spare)
see pics
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Thats going to be one nice Beetle and one happy daughter,nice job.
mcg
Post by mcg »
eish my nightmare
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
Are you planning on keeping the original fuebox? or upgrading to a blade type fusebox?
buggyfan
Long Block
Post by buggyfan »
1969 wiring diagram.
Take it fuse by fuse and follow the wires then youll see it starts getting easier to sort out which wires go where
Theres 3 circuits thats not applicable to Sa bugs
1.F which is a double brakelight switch.We only have 1 brakelight switch with a solid black coming from the fusebox to the switch and a black/red going from te switch to the rear main harness
2 .K7 is a warning light on the dash for the brakelights
3.H5 is a buzzer for doors open or lights on .
mcg
Post by mcg »
Thanks buggyfan i was tempted to put a blade fuse box in
but i think the beetle needs ceramics just part and parcel of a beetle
i can remember always bumping the bloody things in my baja and
all of a sudden having no lights.
64 Notchback
Has thanked: 78 times
Been thanked: 37 times
Post by 64 Notchback »
mcg wrote: Mon Jun 12, 2017 3:11 pm so the hood lining is in
Hi I have a couple sets of window winders if interested.
But you would have to take a set left and right
mcg
Post by mcg »
Thanks 64
all sorted got one in chatsworth for 150.00
mcg
Post by mcg »
okay so everything going nicely front end getting drop adjusters little bit more aggressive look thanks splitfan
body to go on this weekend heating pipes etc fitted
windscreen washer universal fitted could not get
original push button to work i think the rubber diaphram is done.
will update once on pan
small problem with the paint by the windscreen lifted but will sort out when she goes for final cut and polish
buggyfan
Long Block
Post by buggyfan »
The beetle is coming along nicely. :hangloose: :hangloose:
Wiring still a headache??
mcg
Post by mcg »
I havent even attempted to start the wiring yet
just trying to get all the small work done then body on the pan
then wiring
mcg
Post by mcg »
ok guys how low is low for a general daily driver
see piucs
