back fire on accelration
Vintage man
Has thanked: 42 times
Been thanked: 4 times
Flag: South Africa
Post by Vintage man » Tue May 29, 2018 7:25 am
Hi all
Where to start ,1600 TP motor in a late bay.
When accelerating jerks and power low then it back fires.It started doing this and then cleared but this weekend no luck.Checked the timing and dwell angle and that is spot on.
John Alves
Been thanked: 26 times
Flag: South Africa
Re: back fire on accelration
Post by John Alves » Tue May 29, 2018 7:57 am
when does this happen? engine cold? engine hot? all the time? does it happen on deceleration as well?
touch the exhausts see which one is cooler than the rest, possible bad plug??
1958 Ghia
1968 beam bug
Vintage man
Flag: South Africa
Post by Vintage man » Tue May 29, 2018 8:08 am
All the time ,seems only on acceleration .will check plugs and leads as soon as I get a chance.Will check the exhausts as well.Thanks
Eugene
Twin Port
Has thanked: 37 times
Been thanked: 43 times
Flag: Croatia
Post by Eugene » Tue May 29, 2018 9:22 am
No...let John come feel the damn exhausts :twisted:
Has thanked: 136 times
Been thanked: 377 times
Flag: South Africa
Post by Tony Z » Tue May 29, 2018 10:33 am
sounds like the pump jet isnt working as it should
Vintage man
Flag: South Africa
Post by Vintage man » Tue May 29, 2018 11:38 am
Hi Tony ,I will check the pump jet system but it also does it a constant acceleration.Nothing on de-acceleration.
73type2
Oil Seal
Has thanked: 45 times
Been thanked: 40 times
Flag: France
Post by 73type2 » Tue May 29, 2018 12:38 pm
I had a similar issue on my '71 Beetle. I found a leak on the intake manifold.
Flag: South Africa
Post by Tony Z » Tue May 29, 2018 5:40 pm
Then likely a vacuum leak
Flag: South Africa
Post by Tony Z » Tue May 29, 2018 5:41 pm
John Alves
Flag: South Africa
Post by John Alves » Wed May 30, 2018 7:58 am
I now have a laser temp gauge so no more finger burns :)
1958 Ghia
1968 beam bug
Vintage man
Flag: South Africa
Post by Vintage man » Wed May 30, 2018 8:28 am
ok so what temp should it read
John Alves
Flag: South Africa
Post by John Alves » Wed May 30, 2018 10:29 am
the colder one would be the one with the misfire (if the problem is plug related)
1958 Ghia
1968 beam bug
Terry Phillips
What model do you have?: T3,58,60,61beetle
Has thanked: 102 times
Been thanked: 98 times
Flag: South Africa
Post by Terry Phillips » Wed May 30, 2018 2:27 pm
Sucking air use the old hair spray trick, my 2c.
I think I was barking up the wrong tree.I was thinking of de acceleration. :oops:
Last edited by Terry Phillips on Sun Jun 10, 2018 11:03 pm, edited 1 time in total.
Vintage man
Flag: South Africa
Post by Vintage man » Sun Jun 10, 2018 3:34 pm
Reset the volume and bypass on the carb as per Google and runs smooths. Out on the highway and a bit of town driving, I'm chuffed, Thanks all that gave advice as I did do as adviced as well so another learning my bus.
