1500 MOTOR BACKFIRE
- What model do you have?: 1976 T2 Baywindow
1500 MOTOR BACKFIRE
My mechanic has been fighting with the 1500cc motor on the Karmann Ghia for a while now, and he's about to give up.....
Please help with any advice.
Motor starts easily and idles nicely, rev's smoothly up to about 1500rpm and then starts backfiring.
He's checked tappets, timing, played with different jets, checked spark plugs and leads, condensor and coil, fuel line etc etc
Also swapped over everything from my Beetle onto KG and still the same..
- Cyndi Kritzinger
- Facebook: yes
- Been thanked: 64 times
Re: 1500 MOTOR BACKFIRE
AS FAR AS I'M AWARE, A BACKFIRE IS NORMALLY CAUSED BY A TIMING ISSUE BUT I'M NO MECHANIC.
I'LL SPEAK WITH A GOOD MATE OF MINE WHO IS AN OLD SCHOOL VW GUY (AND SERVICE CENTRE OWNER) AND SEE IF HE'S ANY THE WISER.
NO DOUBT THE BOFF'S ON THIS FORUM WILL SORT YOU OUT WITH THEIR PEARLS OF WISDOM.
YOU MAY JUST HAVE TO WAIT FOR THEM TO GET HOME FROM WORK.
MARK
MARK
- Has thanked: 191 times
check for vacuum leaks
where is he setting the timing?
- Been thanked: 539 times
Vacuum pipe is off the dizzy, or sucking air,
manifolds loose and sucking air,
firing order incorrect , make sure you count it clockwise 1-4-3-2
leaking tappets
Crack in head
Good Luck
leaking tappets
Crack in head
Good Luck
- Has thanked: 42 times
- Been thanked: 207 times
Is it backfiring out of the exhaust, sounding like gunshots? Or more like a coughing through carb?
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 321 times
I agree with retrovan and TonyZ, this sounds like a vacuum leak at the manifold. And don't assume it's not the condensor just because you already replaced one. Try another, known good one.
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Don't believe its only something external. You could have internal issues. Leaking valves or cracks as Herman mentioned.
I had a motor in a bus that I purchased last year, that continuously just kept popping out the carb when the revs picked up. What had me stumped is that its compression was 100%, so the valves wren leaking. I eventually discovered the camshaft was completely worn away on 2 lobes and virtually couldn't open the valves...
My mechanic believes you might be on to something here, thanks Sean.sean wrote: โFri Jul 19, 2019 10:06 am Don't believe its only something external. You could have internal issues. Leaking valves or cracks as Herman mentioned.
- sean
Remove the tappet covers and start the motor. Check the rockers if they all have full lift.Jack Nel wrote: โMon Jul 22, 2019 8:49 amMy mechanic believes you might be on to something here, thanks Sean.sean wrote: โFri Jul 19, 2019 10:06 am Don't believe its only something external. You could have internal issues. Leaking valves or cracks as Herman mentioned.
