Disc Brake Conversion
Datwagen
What model do you have?: 1972
Facebook: Stefan De Koker
Post by Datwagen »
Hallo All,
Please i need a bit of advise? I am busy with a disc brake conversion, all round. Now as far as i know the standard master cylinder is a 17 mm or 11/16".
1. Is this correct?
2. Will this size master cylinder be sufficient for the disc brakes?
3. Is it correct that there is a 19 mm or 3/4" master cylinder available?
4. Will the bigger master cylinder be better to use?
Re: Disc Brake Conversion
Are you just doing the front brakes? If so use the standard beetle master cylinder.
If you are doing all round disc brakes you need to use the Golf master cylinder.
Datwagen
Post by Datwagen »
I am doing a all round disc brake. Thanks for the advise.
A split bus MC and resivour is a 100% bolton and will do the job.
boxerulez
What model do you have?: '71 T1 | '75 T2b Ex
Facebook: www.facebook.com/vvzyl
Has thanked: 7 times
Post by boxerulez »
Im tired of struggling with drums.
Which Disc kit allows the standard 5 hole rims to be refitted? Where and how? Just for the front. And then my master will do the job right?
"I'll sleep when I'm dead!"
JamesD
Been thanked: 20 times
Post by JamesD »
boxerulez wrote:Im tired of struggling with drums.
Any, reverse adaptor needed, at home, with tools,Both available and yes. :wink:
thats the short answer.
For the longer more detailed answer:
http://www.aircooledvwsa.co.za/viewtopi ... ilit=+disc
From fastest to slowest:
'75 SP 1600 with a few mods
riaanj
Been thanked: 41 times
Post by riaanj »
hitlers revenge wrote:Are you just doing the front brakes? If so use the standard beetle master cylinder.
??? Golf master cylinder??? will that work? :?:
Boxer, volkspares sells this kit for R5643 and it's got the std 5x205 pcd, don't know about replacement pads & so on, the reverse adapters will be your cheapest option(including the 4x100 golf disk kit) BUT remember they will change your offset/track of the front wheels.. 8)
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Been thanked: 21 times
Post by Ron&Gill »
Golf master cylinder works very well and gives dual circuit safety.
riaanj
Post by riaanj »
Ron&Gill wrote:Golf master cylinder works very well and gives dual circuit safety.
Cool, learnt something new there.. :hangloose:
Honda CBR600RR
Honda CBR600F4
vader
Post by vader »
I used the Toni duel action MS only thing I had to do was bend the rear brake pipe under and around the MS so that it would fit. very easy to install... Oh and I had to adapt the shaft on the brake pedal as the stroke was too long and was jamming the MS when you hit the brakes....
Post by Ron&Gill »
vader wrote:I used the Toni duel action MS only thing I had to do was bend the rear brake pipe under and around the MS so that it would fit. very easy to install... Oh and I had to adapt the shaft on the brake pedal as the stroke was too long and was jamming the MS when you hit the brakes....
There's a spec on the free pedal travel which is the gap between the end of that pin to the master cylinder piston.
Juanrichvw
What model do you have?: Beach buggy
Post by Juanrichvw »
Hi! I'm only looking for the adaptors for front to convert to disc brakes.
Juanrichvw wrote: Thu May 03, 2018 9:59 am Hi! I'm only looking for the adaptors for front to convert to disc brakes.
Give me a call or whatsapp, I can help with the hubs & calliper brackets.
Rui 082 830 6493
