Here's the basic idea...
Use the original vw intake manifold, bolt on a throttle body with internal injector, use the original 6mm fuel line and a Mexican beetle fuel pump... then you end up with something like this
Here's the parts list of what is needed:
-Throttle body
-440cc injector
-Fuel rail
-Throttle position sensor
-Intake manifold adapter
-Air filter adapter
-Beetle specific linkage
-2x return springs
-Hall effect distributor (eg combi 2.1) I'm still working on this part to get a cheaper option
-Mexican beetle fuel pump in surge tank
-Fuel pressure regulator
-3x 8mm to 6mm hose adapters
-2m 6mm high pressure hose
-3m 8mm high pressure hose
-16 Hose clamps
-Electronic ignition coil with plug
-ECU of your choice
There is no return fuel line due to the fuel setup, so less modification.
Here's the intake manifold adapter. It needs to be 8mm thick and uses 4x 6mm Allan caps to hold the throttle body to the adapter and 2x 6mm counter sunk Allan caps with lock nuts to hold the whole assembly on the manifold.
The linkage can be cut from stainless steel and then welded together. The linkage then uses the std beetle barrel nut for the accelerator cable.
I unfortunately did not take any photos while assembling the first kit, but will take detailed notes on the next one.
