how to wire a tachometer
beetle786
Camshaft
Post by beetle786 »
got a sp tachometer how do i wire it to my beetle .
4029
beetle786
Camshaft
Re: sp tachometer
Post by beetle786 »
beetle786 wrote:got a sp tachometer how do i wire it to my beetle .
aka rev counter fellas :lol:
4029
Re: how to wire a tachometer
how many wires and what colours?
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
Just check,ive bumped the SP revcounter installation thread for you
nice one!
Wentzel
Been thanked: 13 times
Post by Wentzel »
The SP tach is current sensing it should be wired into the supply wire to your coil. + from ognition to tach and then from tach to coil. The SP tach thread should have all the details.
Oxyboxer Project
beetle786
Camshaft
Post by beetle786 »
Tony Z wrote:how many wires and what colours?
three pins .
15+ 6 12-
4029
beetle786
Camshaft
Post by beetle786 »
its a vdo
4029
beetle786
Camshaft
Post by beetle786 »
buggyfan wrote:Just check,ive bumped the SP revcounter installation thread for you
thanks will have a look :hangloose:
4029
buggyfan
Long Block
Post by buggyfan »
beetle786 wrote:its a vdo
VDO=Volksies Donner Om :D
Camshaft
Been thanked: 107 times
Post by Haans »
:zhelp: So?.....I've got a needle!!!,....how do i get the "thread" to how to wire this "SP" tacho to my ghia. I hear things like in series and some. Wire from the ignition into tach and then outto the coil ??.
There are some diagram but I could not open it,...suspect it would help
Can anybody out there help ?.......please
Nick
Haans wrote: Tue Aug 01, 2017 5:01 pm :zhelp: So?.....I've got a needle!!!,....how do i get the "thread" to how to wire this "SP" tacho to my ghia. I hear things like in series and some. Wire from the ignition into tach and then outto the coil ??.
Nick
viewtopic.php?f=4&t=24179&p=227096#p227102
Camshaft
Post by Haans »
:huh: Thanks Tony,....I got to this lot of Tony Bishop. There are 4 images,...I could open all except the one for the revcounter.
Pulling it open with the fingers on the I-pad I can make out it isforthe revcounter,.... but quality goes for a ball of sheet.
Is there a way of opening this particulas image with something else?,......ps my expertise with I-pad goes not far more than opening ,closing and getting to the forum!!!
Regards Nick
buggyfan
Long Block
Post by buggyfan »
Try this thread.pic also not opening but @Dawie gives a dtailed explanation .viewtopic.php?f=16&t=12151
buggyfan
Long Block
Post by buggyfan »
Here the info as posted by Tom
