Dome lights .... my 5 day struggle ....help please?
johanmarais
What model do you have?: 1990
Has thanked: 28 times
Post by johanmarais »
I've been trying to get my dome lights to work but for the life of me I can't seem to get it to work when the doors are open.
I've chased it down to behind the fuse box and found this holder.
Now I'm not sure if I should be searching for another holder or a relay.
Any advice would be very helpful
1990 2.1 Caravelle (Auto)
acpaterson
Has thanked: 80 times
Been thanked: 131 times
Re: Dome lights .... my 5 day struggle ....help please?
Post by acpaterson »
No attachment or image,
but as far as I know it shouldn't have any relay. it's a series connection through the door switches through the dome light, and direct to earth.
Has thanked: 42 times
Been thanked: 207 times
Post by Dawie »
12V + goes via fuse to "dome lights". According to Haynes manual, this fuse also supplies cigar lighter socket. So if something stuck into this socket caused fuse to blow, interior lights would also loose power.
Interior lights should always have 12v on one terminal- (red wire). One terminal at light goes to chassis-(brown wire). Third wire from interior light goes to front door switches-(brown/white), the wire at sliding door might be green/white. These switches are all in parrallel. At door switch, this makes contact with chassis when door opens.
If an alarm system was added, there might have been extra wires added to door switches.
johanmarais
Thanks for the reply's. Where does the brown and white wire go to. I know one point is the dome light.... but where is the other point ?
Post by Dawie »
Brown/white wire goes from door switches to dome light.
johanmarais
Between door switch and dome light i have a brown and green wire. Then at the dome light i have the brown and white wire but not sure where it gets its ground from
acpaterson
Could have been changed by the previous owner. joined etc..
Been thanked: 539 times
At the light you have 3 wires.
The power wire from the fuse.
Then you have the wire from the door switches, as said they are in parallel
Then you have another wire, if you trace it, it does not go far, it is connected to the body a little away from the switch.
The Power wire goes to the one side of the light, away from the switch.
The other two go to the switch on the light, so one way the light will stay on, the other way the doors will control the light, these can be connected any way around.
You may have a bad earth on the one connected to the body some way away from the light, to test this, take a wire from a sure earth point and tough it to the light sw point, the light should come on when the doors are closed.
You can also have bad connections on the light sw itself, so clean them 1st.
Good luck
Not sure if this fits your model... look from page 4
viewtopic.php?f=48&t=15500
johanmarais
Thanks all for all the help.... I did manage to fix this eventually.
acpaterson
Well done Johan.
