Bowdem tube
stoffel92
What model do you have?: 1975
Bowdem tube
Post by stoffel92 »
Hi to all.
I need some advise on the bowdem tube. I have done some reseach on the web.
I know it must have a slight bend it it, but mone is straight.
So my question is how do i keep the ben in the tube?
My tube is flexabla, is that normal or does it maen its old and needs replacing?
My main problem is that when i pull away with higher revs than idle the clucth jurks or shudders so bad that it jumps out of gear, but when i pull away without giving gas it does not jurk. I can only give it gas once the clucth is completely released. No problem between gears or when I revaerse
Advise will be greatful
Been thanked: 539 times
Re: Bowdem tube
You will see that the gearbox side has a tube section on it, this can slide backward and forward.
You take the cable out from the release bearing arm, slide the tube out of the sleeve, place washers over the cable and tube section, then put the cable and tube back into the sleeve, the washers will now cause the tube to have a bend in it.
You need the bend to be between 24 and 45 mm, so add or remove washers till you have it right.
Has thanked: 191 times
Been thanked: 487 times
Re: Bowdem tube
As Retro said, you need a bend in the tube.
The reason that your clutch judders at higher rpm launches is because the gearbox is moving and the bowden tube doesnt have any available bend (or slack) to allow the movement without the clutch being affected. So the box moves, the clutch cable pulls tight and the clutch releases a bit which then allows the gearbox to move back and the clutch then engages again causing the box to move which then pulls the clutch cable tight and the clutch releases a bit which then allows the gearbox to move back and the clutch then engages again causing the box to move which then pulls the clutch cable tight and the clutch releases a bit which then allows the gearbox to move back and the clutch then engages again causing the box to move which then pulls the clutch cable tight and the clutch releases a bit which then allows the gearbox to move back and the clutch then engages again causing the box to move which then pulls the clutch cable tight
lol, but seriously, that is what is happening
stoffel92
Re: Bowdem tube
Post by stoffel92 »
Thanks for the advise.
I will try and fit some washers today after work to get the bend right.
Will give some feedback tommorrow.
Thanks allot. Didnt even think to fit so washer and space it away from the fixed arm in order to make the bend
Chardivw
Oil Seal
What model do you have?: 78 kombi 2000l
Facebook: Snowater photography
Has thanked: 12 times
Been thanked: 15 times
Re: Bowdem tube
Post by Chardivw »
Hahahahaha @Tony z.
acpaterson
Has thanked: 80 times
Been thanked: 131 times
Re: Bowdem tube
Post by acpaterson »
lol. Tony Z on form there.. ;-)
brucet
Oil Seal
What model do you have?: '78 2.0 Executive
Has thanked: 72 times
Re: Bowdem tube
Post by brucet »
:lol:
stoffel92
Re: Bowdem tube
Post by stoffel92 »
stoffel92
Re: Bowdem tube
Post by stoffel92 »
To much bend? How does it look?
Will only be able to take it for a test drive in the morning
Re: Bowdem tube
that looks about perfect.
From memory, the bend should be about 30mm from straight
Re: Bowdem tube
By George, I think you got it....
stoffel92
Re: Bowdem tube
Post by stoffel92 »
Morning to all.
Clucth is perfect now. It just takes very heigh.
I gues i can just give it a bit slack so the it takes a bit lower ?
acpaterson
Re: Bowdem tube
Adjust the wingnut on the back to change where it takes. Don't remove any of your washers etc.
Well done, good job.
fourier
Has thanked: 31 times
Been thanked: 37 times
Re: Bowdem tube
Post by fourier »
The sag in the Bowden tube looks good. The Bentley spec for dimension B, is 25-45mm. Too much sag, can result in stiffness in clutch operation, and excessive cable/tube wear. Start with 25mm, and work your way up. Go for as little as is needed for smooth operation.
As mentioned, the wingnut can be adjusted to obtain the correct clutch pedal free-play. The Bentley spec for clutch pedal free-play, is 10-20mm. See what works best for you.
(o= i =o) (o\ ! /o)
