Mid 60's boot lid on 70's beetle
FaanP
What model do you have?: 1971 beetle
Post by FaanP »
Hi,
Can anybody tell me if a 60's beetle boot lid (looking at 66-67) will fit on a a 71 beetle? How much modification is involved to make it fit and did anybody try it yet?
I'm pretty sure I saw it somewhere?
Thanks.
Been thanked: 321 times
Re: Mid 60's boot lid on 70's beetle
I've never done it. To make it work properly you ideally need your chosen engine cover as well as a matching rear valence.
The hinge mountings will be the same, so I suggest you mount your chosen engine cover and then look to see what mods are required to get it to lock. I would expect that will be the main issue, if you are leaving your stock rear valence in place. Bumper clearance is also a possible issue.
FaanP
Post by FaanP »
Thanks Fig.
I like the look of the 60's engine cover and the sloped headlights ....
FaanP wrote: Mon May 15, 2017 1:40 pm Thanks Fig.
Me too. If I were doing this I'd add the 60s fenders, engine cover and valence, as well as the bumpers. However, another issue is the bumper mountings are different and in a different positoon between 60s and 70s Beetles. Paer of the reason for the shape of the 70s engine cover is because of the heavier bumpers; the engine cover is cropped to clear the rear bumper.
