Found that my relay is very slow and the instrument light only worked on the hazards and only one flash on the indicator stalk.
Opened the case for the relay and now nothing works.
What is the replacement relay for this system and where can I get it ?.
Mine has the four pin type with a piggyback terminal to the instrument lamp.
Indicator Relay
- No More Landy
- Has thanked: 23 times
- Been thanked: 5 times
Indicator Relay
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
2021 Polo tsi
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Re: Indicator Relay
Super hard to find originals. Volkspares sell new repops R500+. I used a generic over the counter one as suggested by the guys on here. Works fine
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
Re: Indicator Relay
I'm using a generic, which does work, but I find the actual "lights on" a little too fast. I'd like to get a slower flick that stays on a little longer. Any ideas? (And no, all the bulbs are good, it's not that double speed flick when a bulb's out, just a standard timer, but the lights on timer is too fast for my liking.)
Alan
Alan
- No More Landy
Re: Indicator Relay
I got a generic from Diesel Electric which has terminals 31, 49 49a which is similar to the diagram I have of the original . I assume you merely join the dash light to 49a together with the connections to the indicators ?
1971 Beetle
2021 Polo tsi
2021 Polo tsi
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
Re: Indicator Relay
Yes,thats how they explain it on the Bug me dvd's aswellNo More Landy wrote: ↑Fri Jun 09, 2017 6:53 am I got a generic from Diesel Electric which has terminals 31, 49 49a which is similar to the diagram I have of the original . I assume you merely join the dash light to 49a together with the connections to the indicators ?
- No More Landy
Re: Indicator Relay
Thanks guys,
Is that a DVD or a link on the webs to that ?
1971 Beetle
2021 Polo tsi
2021 Polo tsi
- buggyfan
- Long Block
Re: Indicator Relay
Its a set of dvd's that covers everything there is to know about a B eetle
http://www.bugmevideo.com/volume6.html
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Re: Indicator Relay
Which generic one is it? You getting varying qualities in the aftermarket range.acpaterson wrote: ↑Thu Jun 08, 2017 7:12 pm I'm using a generic, which does work, but I find the actual "lights on" a little too fast. I'd like to get a slower flick that stays on a little longer. Any ideas? (And no, all the bulbs are good, it's not that double speed flick when a bulb's out, just a standard timer, but the lights on timer is too fast for my liking.)
Alan
I forget the name, but I think the ones I have used is Colehersee. This is the one to use. It's quality made in the USA, those Chinese relays are rubbish.
- acpaterson
