Headlight Question !!
- Oil Seal
- Has thanked: 7 times
- Been thanked: 15 times
Hi All,
Sorry for all the questions
My headlight is "stuck" on brights
1 - Park, dash light on
2 - High Beams
If I pull the indicator lever up nothing happens
Can this be a relay on the fusebox ?
2 - High Beams
- Been thanked: 321 times
Re: Headlight Question !!
It's probably the headlight relay getting stuck. Before automatically replacing the relay, try briefly shorting the various terminals against each other. I found that solved the problem for me a few times in the past. (Don't ask me why!)
On one of my buses I had this problem and couldn't solve it. Months later I discovered an ancillary switch that was for spotlights I had removed. When I switched it, then the dipswitch suddenly worked again.
Also check all your fuses.
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
- Oil Seal
I assume the silver one is the headlight relay
My fusebox does not have a cover to indicate what is what
I'll also replace all fuses
Don't assume. Check the diagram on the fuse box cover.
I would check a wiring diagram; you should be able to find one online. IIRC the headlight relay has 5 terminals, if that's any help.
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
Yes thats correct .tThe silver one is the headlight relay .
- Oil Seal
Ok seem that there was a red wire that pulled out
Lever and relay now working but don't have any dim lights
Only high beam and park lights
Twist your fuses or replace it, you may just have a dirty fuse connection.
- Oil Seal
Replaced all fuses for second time
Also sprayed with "Electro" ckeaner
Still just park lights when brights is off
Can it be that both bulbs are shot ??
- Has thanked: 191 times
it could be. I once battled with an electrical issue on my lights.
What solved it was removing each fuse one at a time, then sanding the contacts (in the fuse block) before refitting the fuses. The contacts were the problem, not the fuses...
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
Its quite possible that both your bulbs might be shot. Do you have another switch you can borrow/swap just to rule out a faulty switch ? How do the rear lights look.
Ask someone to check the back for you while you run rear parks, then brakes, then parks with brakes and then both with each indicator going. If you have a disco effect then you will have to check earth connections as well. Do same with front (i.e earth connections)
- Oil Seal
My rear lights is all ok
I tried all combinations
My rear light , front lights, indicators all work fine alone and combined
Just the dim lights not working
Is park lights suppose to burn while the dim / high beam is on as my park lights burn all the time
I do have extra bulbs that I will also test over the weekend
