can you check the distributor drive spacer washer in car?
marcw
What model do you have?: 76 T2 Kombi
Facebook: http://www.facebook.com/marc.wetselaar
Has thanked: 12 times
Been thanked: 6 times
Post by marcw »
Hello, (Type 4 - 2 litre 1976
I have a burning worry and problem that the distributor drive spacer fell out when I put the distributor drive shaft in place.
Symptoms:
1 - there is a ting which is coming from the distributor area of the engine. This was not there when I first put the engine together and at around 200Kms started. It has been getting progressively worse.
2 - the timing is impossible to set as the mark is hunting all over the place. It goes from 5 to 9 degrees at idle and from 28 to 32 degrees at +- 3000RPM.
3 - the timing light is reading 9000RPM when I rev the engine and the rev counter in the dash is sporadically jumping from 3000RPM to 3200RPM. I presume the light is more accurate and reflecting some problem with the distributor.
4 - the engine is spluttering when running; like it is missing once every fourth cycle. (I am not running her on the road.)
Is there any way to check that the spacer/washer (the one with groves on both sides) is in place?
Please don't tell me I have to TAKE OUT THE ENGINE to check this. (I cant face that again.)
Marc
