What you do is the following.No More Landy wrote: ↑Wed Aug 02, 2017 6:25 am Is that measurement with the float removed?
Keep carb on car, loosen all by two opposite screws on float chamber, then turn over the engine with distributor cap off and all parts in the float chamber.
Give it a good few turns to allow the pump to fill float chamber.
Then carefully remove the two screws, and lift the float chamber top with float out of the carb.
Then measure from lip to fuel.
