Clutch Judder
Been thanked: 100 times
Re: Clutch Judder
Those are only M8 bolts.
No More Landy
What model do you have?: Beetle 1971
Has thanked: 23 times
Been thanked: 6 times
Germany
Re: Clutch Judder
Post by No More Landy »
Am aware but think torque wrench a bit out of spec. Will go by experience rather
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
Re: Clutch Judder
I don't know what torque wrench you have, but I had a cheapish torque wrench that didn't work well with low values. The one I have now is a bit more expensive and seems to work better. I also have a needle type one that I use to double check.
Been thanked: 539 times
Re: Clutch Judder
Make sure you on the right scale, as most have foot pounds as well as Nm
Re: Clutch Judder
retrovan wrote: Thu Sep 07, 2017 10:43 am Make sure you on the right scale, as most have foot pounds as well as Nm
Or kgf
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Re: Clutch Judder
Post by Terry Phillips »
FT best of all.
Last edited by Terry Phillips on Thu Sep 07, 2017 11:44 am, edited 1 time in total.
Re: Clutch Judder
Terry Phillips wrote: Thu Sep 07, 2017 11:39 am FT best of all.
Terry, what is FT?
No More Landy
Germany
Re: Clutch Judder
Two poeps tight now. Pitty my appy (son) is away in Latvia for skating championships so I am alone getting engine back in.Image
1971 Beetle
2021 Polo tsi
Terry Phillips
Zambia
Re: Clutch Judder
F____ing Tight It is a family show.
Re: Clutch Judder
Thanks. Now I've learnt another technical term!
No More Landy
Germany
Re: Clutch Judder
We use FT quite a lot in ship repair when tightening nuts with 100 mm plus flogging spanners.
1971 Beetle
2021 Polo tsi
Re: Clutch Judder
Or you can go to the old railway spec.
Strip and a half turn back........
No More Landy
Germany
Re: Clutch Judder
Quick question. If i have both wheels off the ground, 1st gear in and turn one wheel to ensure splines go into clutch. Surely when bellhousing gap almost closed the engine should start to turn?
Or is the diff allowing the other wheel to turn rather than the gearbox input shaft ?
Bit worried now
1971 Beetle
2021 Polo tsi
Re: Clutch Judder
No Because of the reduction ratio to the spigot shaft, it will rather turn the other wheel, and in the opposite direction.
This is normal, but if you block the other wheel, it will take a lot of force to turn the engine.
Thats why the car jerks when you push start it.
No More Landy
Germany
Re: Clutch Judder
Shot. Blocked one wheel and engine turns. Whew
1971 Beetle
2021 Polo tsi
