Is this washer made of rubber and where will I get it ? Called "Guide Ring" in my manual.
Trying to eliminate all knocking sounds from suspension and assume this is one source if this is missing from mine.
Push Rod Washer - Rear Suspension Beetle
- No More Landy
- Has thanked: 23 times
- Been thanked: 5 times
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
2021 Polo tsi
- fourier
- Oil Cooler
- Has thanked: 31 times
- Been thanked: 37 times
Re: Push Rod Washer - Rear Suspension Beetle
It's more like a hard plastic, with a lip below, which clips into the "guide for lever". A rubber grommet will be too soft, and quickly suffer damage from the push rod.
(o= i =o) (o\ ! /o)
- What model do you have?: 73, 74, 77 busses
You can import them, but for the meanwhile you can cut a piece of hosepipe , loosen the bottom nut and washer and slide it over the shaft.fourier wrote:It's more like a hard plastic, with a lip below, which clips into the "guide for lever". A rubber grommet will be too soft, and quickly suffer damage from the push rod.
Sent from my SM-G925F using Tapatalk
- No More Landy
I was buying some Silicone Rubber at Rubber Mouldings and saw some fairly hard rubber washers/grommets the exact size I needed so bought two and slipped them in after removing the bottom nut and washer - found the genuine ones at R100 each but bought these two at R50 together.
1971 Beetle
2021 Polo tsi
2021 Polo tsi
