My Daughter is complaining that the inside door panel securing pins are popping out when she pulls on the inside door handle to close the door.
1971 model.
She lives a bit far away from me to look at it right now, but thought maybe there are supposed to be screws nearby the actual handle keeping it fixed to the steelwork of the door like on other cars I have worked on.
When I replaced the window winder unit the a few months back there was nothing holding the inside door cover other that the press studs/pins if I remember correctly.
Any advise so I know what I need to do when she gets round to visiting Daddy to fix beetle again !
Beetle Inside Door Handle - how is it attached
- No More Landy
- Has thanked: 23 times
- Been thanked: 5 times
- Has thanked: 191 times
Re: Beetle Inside Door Handle - how is it attached
There is a bar that goes behind the panel that the handle bolts onto. This bar also hooks over a tab on the door frame, holding it onto the door
- No More Landy
Thanks. Will be a quick fix hopefullyTony Z wrote:There is a bar that goes behind the panel that the handle bolts onto. This bar also hooks over a tab on the door frame, holding it onto the door
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
2021 Polo tsi
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
This is the type where the doorpanel hooks onto the door as explained by @TonyZ
On later models the handle screw into the door
