WHAT TO USE ON BAYWINDOW FLOOR
Jack Nel
What model do you have?: 1976 T2 Baywindow
Post by Jack Nel »
Any advice on what to use as floor covering on Baywindow floor please, carpet, rubber mat, rubberising? Thanks
Vintage man
Has thanked: 51 times
Been thanked: 7 times
Re: WHAT TO USE ON BAYWINDOW FLOOR
Post by Vintage man »
I think it will be a matter of opion.I will go with a thin rubber and a removable carpet.Easy to clean and can leave the carpet out for camping trips ect.
Cyndi Kritzinger
Facebook: yes
Been thanked: 64 times
Post by Cyndi Kritzinger »
DO NOT RUBBERISE.
DEPENDS ON USE. IN CYNDI'S BUS WE LAID A THIN PLY AND THEN A VINYL. EASY TO CLEAN AFTER GOING FOR A SURF OR CAMP.
IN MINE I HAVE HEAVY DUTY CAR CARPET. LOOKS GREAT AND STYLISH BUT IT'S A LOT OF WORK TO KEEP CLEAN, ALSO THE UNDERFELT HOLDS MOISTURE IF IT GETS WET.
Jack Nel
Post by Jack Nel »
For me it needs to be easy to clean and still look good even though it is being used. I thought thin rubber with carpet over it will do the job.
Why not rubberise?
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Laminated flooring with under floor layer of foam or what ever they call it.Fitted to both my campers and can take a punishing and easy to clean.One can take them out easy if you want to clean under the floor.My 2 cents worth.
Been thanked: 539 times
Get a heavy rubber mat cut to fit wall to wall, then plaxe a cleanable carpet on top.
As said, when you know the dog is going with or its a dirty trip, leave the carpet at home.
When you get back rubber mat on driveway, hose it down, let dry, van as good as new with little effort.
Cyndi Kritzinger
Facebook: yes
MOISTURE GETS TRAPPED UNDER THE RUBBERISING AND THE ROT STARTS. YOU DON'T SEE IT TILL IT'S WAY TOO LATE.
Jack Nel
Post by Jack Nel »
Makes sense that rubberizing can cause problems. Not sure yet what I will do with my floor, but figured that it should have a thin rubber base and then a "fancy" top cover over the rubber, probably carpet.
Has thanked: 191 times
Been thanked: 487 times
rubber also attracts moisture and keeps it from evaporating. Make sure whatever you do is breathable.
