Nissan 1400 Head Light conversion Early Bay
- Has thanked: 193 times
- Been thanked: 121 times
Any one done this conversion on a Early Bay what needs doing.
Re: Nissan 1400 Head Light conversion Early Bay
Have not done it myself, but am lead to believe the 7 inch H4 semi sealed is a direct replacement and can be got at any parts store.
- Has thanked: 191 times
I fitted 7" hella lights not too long ago.
Honestly, I'd have preferred it if they were a little larger, maybe 7.5"
If you have mounting tabs inside the light bucket, then its a simple swap. If not, then you have to make a plan
- sean
- Has thanked: 63 times
- Been thanked: 227 times
I'm a little confused here. Are Nissan 1400 lights not square?
I'm struggling to understand why you want to fit square lights into a Kombi???
- Eugene
- Has thanked: 59 times
- Been thanked: 65 times
- Jdt1976
- Has thanked: 114 times
- Been thanked: 90 times
I was also thinking before your time
Was teaching myself to drive in a 1200. They were good doing 180's and 360's on the gravel roads those days....
- Has thanked: 78 times
- Been thanked: 37 times
- sean
Ok, but those are the 1200 bakkies. I was under the impression the later 1400 has square lights....
But hey, Japcrap is not my strong point.
