Hi all
I have a situation where rats have chewed the two wires off what I think are the fuel injectors on an Opel Corsa 1.4
Are these easily replaced.
The car belongs to our domestic worker and she wants to use it to go home for Christmas
Another non aircooled question
- Has thanked: 78 times
- Been thanked: 37 times
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
Re: Another non aircooled question
Yes , its only a earth and signal wire per injector
- Has thanked: 51 times
- Been thanked: 7 times
Hi all
Thanks for replies this is the damage done to the injectors. Can I just replace the white plug on top and if so how does it unplug and where can I get one.
- slak
- Has thanked: 7 times
- Been thanked: 32 times
Those plugs are usually available from your nearest Diesel Electric
U Only Live Once Right !!!
- splitfan
You have to press the wire release to unplug , Goldwagen also stock the plugs
Thanks for all responses.
We have booked the vehicle in at Budler Motor sport in Jan to have it fixed.
