Firing issues !!
spicydave
Oil Seal
What model do you have?: 1973
Has thanked: 7 times
Been thanked: 15 times
Firing issues !!
Post by spicydave »
Hi All,
Fitted another dual set of carbs with lower manifolds
Connected all wires from coil to both carbs
Just running on piston 1 & 2
Manifold of puston 3 & 4 “cold as a lady of nights heart”
There is fuel when I open the throttle
What will the reason be ?
Has thanked: 191 times
Been thanked: 487 times
Re: Firing issues !!
plug wires the wrong way round?
blocked idle jets
idle solenoid closed
unbalanced carbs
idle mixture adjuster screwed all the way in
vacuum leaks
spicydave
Oil Seal
Post by spicydave »
Tx Tony
Will open carbs and clean all parts
spicydave
Oil Seal
Post by spicydave »
All sorted
Cleaned the carbs and started
