If you fit an external oil filter is it still necessary to fit a oil strainer?
External filter & oil strainer
- dixtoy
- Has thanked: 60 times
- Been thanked: 37 times
1959 Beetle (Lindor)
1975 Fleetline panel (Ouvrou)
1971 Westy (Gypsy)
1971 Westy (Gypsy)
- Camshaft
- Been thanked: 107 times
Re: External filter & oil strainer
Dix,.....I wonder what the gurus will say,......if you leave the strainer,.....what it affect ? Nothing I think, but then again,... I do not know for sure
Gurus ?
Gurus ?
- Has thanked: 193 times
- Been thanked: 121 times
I would say yes as the strainer is protecting the oil pump from picking up foreign objects from entering the oil pump and the oil filter keeps the oil clean. My 2c worth in short.
and the strainer stops the pickup tube from rattling around and falling out - ok, it is still bolted on, but the strainer helps - plus it doesnt provide a restriction, so why take it out?
- dixtoy
I was thinking to tap a oil temp sensor into the plate and I think the strainer will be in the way. I’ll leave it and do something at the drain plugTony Z wrote:and the strainer stops the pickup tube from rattling around and falling out - ok, it is still bolted on, but the strainer helps - plus it doesnt provide a restriction, so why take it out?
1971 Westy (Gypsy)
1971 Westy (Gypsy)
