Can you use a Golf oil filter on a type 4?
stew 89
Has thanked: 12 times
Flag: South Africa
Post by stew 89 » Sat Feb 03, 2018 8:28 am
Morning guys and gals,
Can I use a city/mk2 golf oil filter on my type4 ? Reason, no one in Durban has the proper filter. I think the golf one is longer but because I dont go off road im not stressed about that.
Shot in advance for the help.
Stew
Jdt1976
Has thanked: 87 times
Been thanked: 71 times
Flag: South Africa
Re: Can you use a Golf oil filter on a type 4?
Post by Jdt1976 » Sat Feb 03, 2018 8:36 am
I can buy one in JHB and transport it down to you
stew 89
Flag: South Africa
Post by stew 89 » Sat Feb 03, 2018 8:42 am
@ Jdt1976
Thanks mate I was kinda hopping to do a service this weekend. If I don't come right I'll call on you :)
Thank though.
Has thanked: 152 times
Been thanked: 377 times
Flag: Netherlands
Post by retrovan » Sat Feb 03, 2018 9:17 am
The only thing you need to match is the tread and the resistance to oil flow,
The bigger filter should give you less resistance, and thats what you want.
So if you can find these out, you can do it.
Best if the filter has a By-Pass valve then you know you safe.
1952 Split Beetle 1835cc (Azure Blue)
1968 Fastback 2Lt.type4( Red)
1972 Low Light Bay Panel Van 2Lt type 4(White)
1975 Fleetline Panel Van 1914cc (Aqua Blue/White)
2019 MeFusco Beetle Truck
Has thanked: 136 times
Been thanked: 378 times
Flag: South Africa
Post by Tony Z » Sat Feb 03, 2018 1:44 pm
the spares shops also have filter catalogs. You can go in with your filter number and they will check it against their catalog - thread size, OD, ID... and find one that matches.
Jdt1976
Flag: South Africa
Post by Jdt1976 » Sat Feb 03, 2018 2:30 pm
@ Jdt1976
Thank though.
If it is the Z80, I did have a look, got 4 here.
One of my drivers are leaving tomorrow, will be in Durban on Monday.
stew 89
Flag: South Africa
Post by stew 89 » Sat Feb 03, 2018 4:24 pm
Thanks Guys I have made a plane. I found one at a Midus.
Than you very much :)
