Hello, (on my type 4 2 litre CU heads - square exhaust port)
I have read that the head gasket for the type 4 2 litre should be dropped. What are the views of everyone here?
I had the cylinder and the head directly together with no gasket and have some blow by on the number 2 cylinder. All the others are fine and sealed.
Is this just a bad cylinder, head, or mechanic error? Or should I have used a cylinder head gasket as comes with all the gasket packs for the type 4?
Marc
Type 4 2 litre CU heads (gasket or no gasket)
- marcw
- Has thanked: 12 times
- Been thanked: 6 times
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Re: Type 4 2 litre CU heads (gasket or no gasket)
I’ve never had a motor without them in. I think most of mine have 2 installed per cylinder. This is for the deck height though, not sure of how it effects the sealing. You would have to skim those heads and barrels to avoid this re appearing.
- eben
- Site Admin
- Been thanked: 54 times
Here is a link to the Technical bulletin about this topic:
viewtopic.php?f=48&t=20095
- marcw
Thank you Eben - that is what I had read as well - just checking.
